주요 콘텐츠로 건너뛰기
VTech Kidizoom Camera Connect Power Distribution Circuit Board Replacement
필요한 것
  1. VTech Kidizoom Camera Connect  Power Distribution Circuit Board Replacement, Front Case: 1 단계, 이미지 2개 중 1개 VTech Kidizoom Camera Connect  Power Distribution Circuit Board Replacement, Front Case: 1 단계, 이미지 2개 중 2개
    • Remove batteries and SD card before beginning disassembly!
    • Locate the four plastic screw covers denoted by the markers and gently pry them up with the metal spudger.
  2. VTech Kidizoom Camera Connect  Power Distribution Circuit Board Replacement: 2 단계, 이미지 2개 중 1개 VTech Kidizoom Camera Connect  Power Distribution Circuit Board Replacement: 2 단계, 이미지 2개 중 2개
    • Remove all four (11mm) screws with the Philips #0 screwdriver.
  3. VTech Kidizoom Camera Connect  Power Distribution Circuit Board Replacement: 3 단계, 이미지 3개 중 1개 VTech Kidizoom Camera Connect  Power Distribution Circuit Board Replacement: 3 단계, 이미지 3개 중 2개 VTech Kidizoom Camera Connect  Power Distribution Circuit Board Replacement: 3 단계, 이미지 3개 중 3개
    • Remove the two battery cartridges located on the underside of the camera.
    • Once cartridges are removed, use the metal spudger to pry open the top, bottom, and both sides of the camera.
  4. VTech Kidizoom Camera Connect  Power Distribution Circuit Board Replacement: 4 단계, 이미지 1개 중 1개
    • Beware of the two black viewfinder lens falling out as you pry open the device!
    • The device should now be open and ready for further repair and/or replacement parts.
  5. VTech Kidizoom Camera Connect  Power Distribution Circuit Board Replacement, Motherboard: 5 단계, 이미지 1개 중 1개
    • Locate and remove the screws circled in the provided image with a Philips #0 screwdriver.
  6. VTech Kidizoom Camera Connect  Power Distribution Circuit Board Replacement: 6 단계, 이미지 2개 중 1개 VTech Kidizoom Camera Connect  Power Distribution Circuit Board Replacement: 6 단계, 이미지 2개 중 2개
    • Unsolder the connection points on the motherboard.
  7. VTech Kidizoom Camera Connect  Power Distribution Circuit Board Replacement: 7 단계, 이미지 3개 중 1개 VTech Kidizoom Camera Connect  Power Distribution Circuit Board Replacement: 7 단계, 이미지 3개 중 2개 VTech Kidizoom Camera Connect  Power Distribution Circuit Board Replacement: 7 단계, 이미지 3개 중 3개
    • Unsolder the connections to the right battery terminal. Removing the terminal allows easier access to the motherboard.
  8. VTech Kidizoom Camera Connect  Power Distribution Circuit Board Replacement: 8 단계, 이미지 3개 중 1개 VTech Kidizoom Camera Connect  Power Distribution Circuit Board Replacement: 8 단계, 이미지 3개 중 2개 VTech Kidizoom Camera Connect  Power Distribution Circuit Board Replacement: 8 단계, 이미지 3개 중 3개
    • Carefully pull up on the motherboard and pink plastic underneath the motherboard. The pink plastic contains the display and is connected to the motherboard.
  9. VTech Kidizoom Camera Connect  Power Distribution Circuit Board Replacement, Power Distribution Circuit Board: 9 단계, 이미지 1개 중 1개
    • Unsolder the wires connected to the power distribution circuit board.
  10. VTech Kidizoom Camera Connect  Power Distribution Circuit Board Replacement: 10 단계, 이미지 1개 중 1개
    • Locate and remove the two screws that hold in the power distribution circuit board using a Philips #0 screwdriver.
  11. VTech Kidizoom Camera Connect  Power Distribution Circuit Board Replacement: 11 단계, 이미지 1개 중 1개
    • Gently pull up on power distribution circuit board and remove it from the device.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
1다른 기여자 명과 함께
Justin Sanchez
회원 가입일: 02/08/16
544 평판
안내서 4개를 작성함
USF Tampa, Team 6-4, Eyestone Spring 2016 USF Tampa, Team 6-4, Eyestone Spring 2016 회원
USFT-EYESTONE-S16S6G4
4 회원들
안내서 5개를 작성함
1가이드 댓글
The Camera is not working anymore. We can`t switch it on, so it could be that the distribution circiut is damaged.
What kind of disitrubution circiut is it? I want to order a spare part.
Babyface - 답글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 4
지난 30일: 19
전체 시간: 1,570
