주요 콘텐츠로 건너뛰기
VTech Kidizoom Camera Connect Front Case Replacement
필요한 것
  1. VTech Kidizoom Camera Connect Front Case Replacement, Front Case: 1 단계, 이미지 1/2 VTech Kidizoom Camera Connect Front Case Replacement, Front Case: 1 단계, 이미지 2/2
    • Remove batteries and SD card before beginning disassembly!
    • Locate the four plastic screw covers denoted by the markers and gently pry them up with the metal spudger.
  2. VTech Kidizoom Camera Connect Front Case Replacement: 2 단계, 이미지 1/2 VTech Kidizoom Camera Connect Front Case Replacement: 2 단계, 이미지 2/2
    • Remove all four (11mm) screws with the Philips #0 screwdriver.
  3. VTech Kidizoom Camera Connect Front Case Replacement: 3 단계, 이미지 1/3 VTech Kidizoom Camera Connect Front Case Replacement: 3 단계, 이미지 2/3 VTech Kidizoom Camera Connect Front Case Replacement: 3 단계, 이미지 3/3
    • Remove the two battery cartridges located on the underside of the camera.
    • Once cartridges are removed, use the metal spudger to pry open the top, bottom, and both sides of the camera.
  4. VTech Kidizoom Camera Connect Front Case Replacement: 4 단계, 이미지 1/1
    • Beware of the two black viewfinder lens falling out as you pry open the device!
    • The device should now be open and ready for further repair and/or replacement parts.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Nick Foster
회원 가입일: 02/14/16
288 평판
안내서 1개 작성함
USF Tampa, Team 6-4, Eyestone Spring 2016 USF Tampa, Team 6-4, Eyestone Spring 2016 회원
USFT-EYESTONE-S16S6G4
4 회원들
안내서 5개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 6
30일 전: 40
전체 시간: 4,092
