주요 콘텐츠로 건너뛰기
VTech Kidizoom Camera Connect Motherboard Replacement
필요한 것
  1. VTech Kidizoom Camera Connect Motherboard Replacement, Front Case: 1 단계, 이미지 2개 중 1개 VTech Kidizoom Camera Connect Motherboard Replacement, Front Case: 1 단계, 이미지 2개 중 2개
    • Remove batteries and SD card before beginning disassembly!
    • Locate the four plastic screw covers denoted by the markers and gently pry them up with the metal spudger.
  2. VTech Kidizoom Camera Connect Motherboard Replacement: 2 단계, 이미지 2개 중 1개 VTech Kidizoom Camera Connect Motherboard Replacement: 2 단계, 이미지 2개 중 2개
    • Remove all four (11mm) screws with the Philips #0 screwdriver.
  3. VTech Kidizoom Camera Connect Motherboard Replacement: 3 단계, 이미지 3개 중 1개 VTech Kidizoom Camera Connect Motherboard Replacement: 3 단계, 이미지 3개 중 2개 VTech Kidizoom Camera Connect Motherboard Replacement: 3 단계, 이미지 3개 중 3개
    • Remove the two battery cartridges located on the underside of the camera.
    • Once cartridges are removed, use the metal spudger to pry open the top, bottom, and both sides of the camera.
  4. VTech Kidizoom Camera Connect Motherboard Replacement: 4 단계, 이미지 1개 중 1개
    • Beware of the two black viewfinder lens falling out as you pry open the device!
    • The device should now be open and ready for further repair and/or replacement parts.
  5. VTech Kidizoom Camera Connect Motherboard Replacement, Motherboard: 5 단계, 이미지 1개 중 1개
    • Locate and remove the screws circled in the provided image with a Philips #0 screwdriver.
  6. VTech Kidizoom Camera Connect Motherboard Replacement: 6 단계, 이미지 2개 중 1개 VTech Kidizoom Camera Connect Motherboard Replacement: 6 단계, 이미지 2개 중 2개
    • Unsolder the connection points on the motherboard.
  7. VTech Kidizoom Camera Connect Motherboard Replacement: 7 단계, 이미지 3개 중 1개 VTech Kidizoom Camera Connect Motherboard Replacement: 7 단계, 이미지 3개 중 2개 VTech Kidizoom Camera Connect Motherboard Replacement: 7 단계, 이미지 3개 중 3개
    • Unsolder the connections to the right battery terminal. Removing the terminal allows easier access to the motherboard.
  8. VTech Kidizoom Camera Connect Motherboard Replacement: 8 단계, 이미지 3개 중 1개 VTech Kidizoom Camera Connect Motherboard Replacement: 8 단계, 이미지 3개 중 2개 VTech Kidizoom Camera Connect Motherboard Replacement: 8 단계, 이미지 3개 중 3개
    • Carefully pull up on the motherboard and pink plastic underneath the motherboard. The pink plastic contains the display and is connected to the motherboard.
결론
다른 5명이 해당 안내서를 완성하였습니다.
작성자
1다른 기여자 명과 함께
Justin Sanchez
회원 가입일: 02/08/16
544 평판
안내서 4개를 작성함
USF Tampa, Team 6-4, Eyestone Spring 2016 USF Tampa, Team 6-4, Eyestone Spring 2016 회원
USFT-EYESTONE-S16S6G4
4 회원들
안내서 5개를 작성함
1가이드 댓글
Do you know what the replacement mic is? My girls mic has stopped working. Sound still plays, but can’t record voice or sound for video making. Thanks Tim
Timothy GRAHAM - 답글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 4
지난 30일: 17
전체 시간: 2,711
