소개
Use this guide to remove and replace the speaker.
필요한 것
Locate the four plastic screw covers denoted by the markers and gently pry them up with the metal spudger.
Locate and remove the screws circled in the provided image with a Philips #0 screwdriver.
The speaker is glued in so you must use the metal spudger to break the seal made by the glue.
거의 끝나갑니다!
결론
다른 한 분이 해당 안내서를 완성하였습니다.
