소개
If your Smartwatch is not charging, and you tested the cables, then the battery may need to be replaced. This guide will show you how to do this.
필요한 것
Carefully pry the battery off of the circuit board using the plastic opening tool.
거의 끝나갑니다!
결론
댓글 4개
Hey guys, My VTech watch is plugged in but once I turn it on it does but then shows a dead battery. I actually didn’t play with it for a while and I left it dead battery.
So I might try this trick and see if it works.
Sometime i’ll try it
when I have the right tools
