소개
If your Smartwatch is not charging, and you tested the cables, then the battery may need to be replaced. This guide will show you how to do this.
필요한 것
이 단계에 사용된 도구:Tweezers$4.99
Using the tweezers, carefully lift the bar holding the connection to the screen.
Remove the motherboard from the device.
I'm trying to replace the microphone. Will replacing the motherboard get me a new microphone? I don't see it listed as a replacement part.
Carefully pry the battery off of the circuit board using the plastic opening tool.
다른 한 분이 해당 안내서를 완성하였습니다.
댓글 4개
Hey guys, My VTech watch is plugged in but once I turn it on it does but then shows a dead battery. I actually didn’t play with it for a while and I left it dead battery.
So I might try this trick and see if it works.
Sometime i’ll try it
when I have the right tools
