주요 콘텐츠로 건너뛰기
VTech Kidizoom Smartwatch DX2 Faceplate Replacement
필요한 것
  1. VTech Kidizoom Smartwatch DX2 Faceplate Replacement, Faceplate: 1 단계, 이미지 1/1
    • In order to remove the faceplate you must start by placing the watch screen upwards.
  2. VTech Kidizoom Smartwatch DX2 Faceplate Replacement: 2 단계, 이미지 1/1
    • Use iFixit’s opening tool, another similar tool, or simply use your fingernail to gently pry open the faceplate away from the screen starting from an edge.
    • You may hear a popping sound, but this is normal.
  3. VTech Kidizoom Smartwatch DX2 Faceplate Replacement: 3 단계, 이미지 1/1
    • Once successful, pull the remaining faceplate off from the watch.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Jessica Richard
회원 가입일: 10/25/18
512 평판
안내서 4개 작성하였습니다
UMass Dartmouth, Team S3-G5, Peak Fall 2018 UMass Dartmouth, Team S3-G5, Peak Fall 2018 회원
UMASSD-PEAK-F18S3G5
4 회원들
안내서 7개 작성하였습니다
댓글 4개
Where can I find a faceplate?
Sammi Schummer - 답글
Where can you buy a replacement face plate?
Natalie - 답글
This doesn't remove the faceplate, just the decorative bezel around the screen. I'm looking for disassembly instructions to open up the screen as my son wore his I to the pool (immediately after being told not to! Kids…)
Jack Wesselo - 답글
Where can I get a replacement faceplate please
Steph Crowe - 답글
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 3
30일 전: 11
전체 시간: 2,522
