소개
In order to remove the screen or the battery, the main board will have to be removed first. Follow this guide to set you on your way.
필요한 것
Using the tweezers, carefully lift the bar holding the connection to the screen.
Remove the motherboard from the device.
I'm trying to replace the microphone. Will replacing the motherboard get me a new microphone? I don't see it listed as a replacement part.
다른 4명이 해당 안내서를 완성하였습니다.
댓글 2개
I’m interested in the components on the motherboard. What type of SOC does it use, what operating system, etc…
