이 버전에는 잘못된 편집 사항이 있을 수 있습니다. 최신 확인된 스냅샷으로 전환하십시오.
필요한 것
이 단계는 번역되지 않았습니다. 번역을 도와주십시오
Next, use the Phillips #00 screwdriver to unscrew the four 6.0 mm screws located in each corner of the watch to remove the backplate.
After removing the backplate, lift the master switch up from the circuit board.
Carefully remove the speaker from the case without disconnecting it from the motherboard.
Using the tweezers, carefully lift the bar holding the connection to the screen.
Remove the motherboard from the device.
다른 4명이 해당 안내서를 완성하였습니다.
댓글 2개
I’m interested in the components on the motherboard. What type of SOC does it use, what operating system, etc…
