주요 콘텐츠로 건너뛰기
VTech Kidizoom Smartwatch DX2 Speakers Replacement
필요한 것
  1. VTech Kidizoom Smartwatch DX2 Speakers Replacement, Master Switch: 1 단계, 이미지 2개 중 1개 VTech Kidizoom Smartwatch DX2 Speakers Replacement, Master Switch: 1 단계, 이미지 2개 중 2개
    • Begin by flipping the watch over with its back facing upwards.
  2. VTech Kidizoom Smartwatch DX2 Speakers Replacement: 2 단계, 이미지 2개 중 1개 VTech Kidizoom Smartwatch DX2 Speakers Replacement: 2 단계, 이미지 2개 중 2개
    • Next, use the Phillips #00 screwdriver to unscrew the four 6.0 mm screws located in each corner of the watch to remove the backplate.
  3. VTech Kidizoom Smartwatch DX2 Speakers Replacement: 3 단계, 이미지 2개 중 1개 VTech Kidizoom Smartwatch DX2 Speakers Replacement: 3 단계, 이미지 2개 중 2개
    • Gently lift the backplate up to remove it.
  4. VTech Kidizoom Smartwatch DX2 Speakers Replacement: 4 단계, 이미지 3개 중 1개 VTech Kidizoom Smartwatch DX2 Speakers Replacement: 4 단계, 이미지 3개 중 2개 VTech Kidizoom Smartwatch DX2 Speakers Replacement: 4 단계, 이미지 3개 중 3개
    • After removing the backplate, lift the master switch up from the circuit board.
  5. VTech Kidizoom Smartwatch DX2 Speakers Replacement, Motherboard: 5 단계, 이미지 1개 중 1개
    • Using a Phillips #00 screwdriver, remove the 0.6 mm screw.
  6. VTech Kidizoom Smartwatch DX2 Speakers Replacement: 6 단계, 이미지 2개 중 1개 VTech Kidizoom Smartwatch DX2 Speakers Replacement: 6 단계, 이미지 2개 중 2개
    • Carefully remove the speaker from the case without disconnecting it from the motherboard.
  7. VTech Kidizoom Smartwatch DX2 Speakers Replacement: 7 단계, 이미지 2개 중 1개 VTech Kidizoom Smartwatch DX2 Speakers Replacement: 7 단계, 이미지 2개 중 2개
    이 단계에 사용된 도구:
    • Using the tweezers, carefully lift the bar holding the connection to the screen.
    • Remove the motherboard from the device.
  8. VTech Kidizoom Smartwatch DX2 Speakers Replacement, Speakers: 8 단계, 이미지 1개 중 1개
    • Carefully desolder the speaker from the board.
    • Be careful to not desolder the battery cable.
결론
작성자
3다른 기여자 명과 함께
Jessica Richard
회원 가입일: 10/25/18
512 평판
안내서 4개를 작성함
UMass Dartmouth, Team S3-G5, Peak Fall 2018 UMass Dartmouth, Team S3-G5, Peak Fall 2018 회원
UMASSD-PEAK-F18S3G5
4 회원들
안내서 7개를 작성함
댓글 한 개
hi, where did you buy the spare speaker?
minhhai79 - 답글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 2
지난 30일: 17
전체 시간: 847
