소개
If the speakers on your watch are not working, cracked, or damaged in anyway it will need to be replaced. The following guide will show you how.
필요한 것
이 단계에 사용된 도구:Tweezers$4.99
Using the tweezers, carefully lift the bar holding the connection to the screen.
Remove the motherboard from the device.
I'm trying to replace the microphone. Will replacing the motherboard get me a new microphone? I don't see it listed as a replacement part.
Carefully desolder the speaker from the board.
Be careful to not desolder the battery cable.
거의 끝나갑니다!
결론
