주요 콘텐츠로 건너뛰기
VTech Kidizoom Smartwatch DX2 Wristband Replacement
필요한 것
  1. VTech Kidizoom Smartwatch DX2 Wristband Replacement, Wristband: 1 단계, 이미지 1개 중 1개
    • Begin by placing the watch on its side.
  2. VTech Kidizoom Smartwatch DX2 Wristband Replacement: 2 단계, 이미지 1개 중 1개
    • Next, use the flat end of the spudger to wedge between the small-headed pin (located on the band closest to the watch) to pull the pin up through the other side.
  3. VTech Kidizoom Smartwatch DX2 Wristband Replacement: 3 단계, 이미지 1개 중 1개
    • Pull the pin out, however not fully, feeling slight resistance is normal.
  4. VTech Kidizoom Smartwatch DX2 Wristband Replacement: 4 단계, 이미지 1개 중 1개
    • Finally, pull the wristband off. Repeat on the opposite side of the watch if necessary.
결론
작성자
2다른 기여자 명과 함께
Sydney
회원 가입일: 10/25/18
344 평판
안내서 2개를 작성함
UMass Dartmouth, Team S3-G5, Peak Fall 2018 UMass Dartmouth, Team S3-G5, Peak Fall 2018 회원
UMASSD-PEAK-F18S3G5
4 회원들
안내서 7개를 작성함
댓글 2개
My Vtech DX2 had a split pin. One side of the pin was the long side and the other very very short. So look out for that. Thanks for this tutorial, was very helpful.
Ryan Laurel - 답글
Where can I buy a replacement wristband for dx2? Thanks
Ari - 답글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 4
지난 30일: 20
전체 시간: 7,534
