주요 콘텐츠로 건너뛰기
VTech Learning Tunes Karaoke Mode Selector Replacement
필요한 것
  1. VTech Learning Tunes Karaoke Mode Selector Replacement, Mode Selector: 1 단계, 이미지 1/1
    • To remove the battery door, loosen the 4mm Flathead screw.
    • A coin can also be used to loosen the screw.
  2. VTech Learning Tunes Karaoke Mode Selector Replacement: 2 단계, 이미지 1/2 VTech Learning Tunes Karaoke Mode Selector Replacement: 2 단계, 이미지 2/2
    • Remove the battery door and take out the batteries.
  3. VTech Learning Tunes Karaoke Mode Selector Replacement: 3 단계, 이미지 1/1
    • Remove the six 9.5 mm Phillips #2 screws.
    • Remove the six 6.0 mm Phillips #2 screws.
  4. VTech Learning Tunes Karaoke Mode Selector Replacement: 4 단계, 이미지 1/2 VTech Learning Tunes Karaoke Mode Selector Replacement: 4 단계, 이미지 2/2
    • Gently pull up on the rear panel.
    • Be careful to not pull on the wire connections.
    • Gently place the back panel underneath the top panel with the tops facing each other, as shown in the picture.
  5. VTech Learning Tunes Karaoke Mode Selector Replacement: 5 단계, 이미지 1/1
    • Remove the two 7.9 mm Phillips #1 mode switch board screws.
  6. VTech Learning Tunes Karaoke Mode Selector Replacement: 6 단계, 이미지 1/2 VTech Learning Tunes Karaoke Mode Selector Replacement: 6 단계, 이미지 2/2
    • Once the screws have been removed, carefully move the mode switch board to expose the mode switch assembly underneath.
  7. VTech Learning Tunes Karaoke Mode Selector Replacement: 7 단계, 이미지 1/2 VTech Learning Tunes Karaoke Mode Selector Replacement: 7 단계, 이미지 2/2
    • Using a Philips #1 screwdriver, remove the two 5.6 mm screws on the switch.
    • Once the screws have been removed, you can easily remove the mode switch.
결론
Adam Chaberek
회원 가입일: 02/09/16
137 평판
안내서 1개 작성함
USF Tampa, Team 7-2, Cheng Spring 2016 USF Tampa, Team 7-2, Cheng Spring 2016 회원
USFT-CHENG-S16S7G2
4 회원들
안내서 10개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 1
30일 전: 8
전체 시간: 295
