주요 콘텐츠로 건너뛰기
VTech Record and Learn KidiStudio Whammy Bar Replacement
필요한 것
  1. VTech Record and Learn KidiStudio Whammy Bar Replacement, Whammy Bar: 1 단계, 이미지 1/2 VTech Record and Learn KidiStudio Whammy Bar Replacement, Whammy Bar: 1 단계, 이미지 2/2
    • Unscrew 11 PH2 screws (7 mm).
    • Remove black plastic backing.
    • Remove the batteries from the toy before beginning replacement of the whammy bar.
  2. VTech Record and Learn KidiStudio Whammy Bar Replacement: 2 단계, 이미지 1/2 VTech Record and Learn KidiStudio Whammy Bar Replacement: 2 단계, 이미지 2/2
    • Remove PH2 screw (5 mm) from yellow/gold colored circuit board and pull back to access the whammy component.
  3. VTech Record and Learn KidiStudio Whammy Bar Replacement: 3 단계, 이미지 1/2 VTech Record and Learn KidiStudio Whammy Bar Replacement: 3 단계, 이미지 2/2
    • Remove 3 PH2 (5 mm) screws connected to the whammy bar component.
    • Remove blue piece from back of the device. This will free the whammy bar. Replace the whammy bar with new part.
결론
Shaina Carbonel
회원 가입일: 02/01/16
537 평판
안내서 5개 작성하였습니다
UW Tacoma, Team 1-1, Rose Winter 2016 UW Tacoma, Team 1-1, Rose Winter 2016 회원
UWT-ROSE-W16S1G1
5 회원들
안내서 10개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 3
30일 전: 4
전체 시간: 209
