주요 콘텐츠로 건너뛰기
VTech Safe And Sound DM221 Speaker Replacement
필요한 것
  1. VTech Safe And Sound DM221 Speaker Replacement, Speaker: 1 단계, 이미지 1/1
    • Remove the battery cover.
  2. VTech Safe And Sound DM221 Speaker Replacement: 2 단계, 이미지 1/1
    • Unplug the battery from its connector and remove.
  3. VTech Safe And Sound DM221 Speaker Replacement: 3 단계, 이미지 1/1
    • Using the Phillips #00 screwdriver, unscrew the two 5.0 mm Phillips #00 screws at the bottom of the monitor.
  4. VTech Safe And Sound DM221 Speaker Replacement: 4 단계, 이미지 1/1
    • Separate the back half of the device from the front using the metal spudger.
  5. VTech Safe And Sound DM221 Speaker Replacement: 5 단계, 이미지 1/1
    • Remove the two 5.0 mm Phillips #00 screws at the top of the device which holds the antenna at the top of the motherboard.
    • This will allow the removal of the silver handle.
  6. VTech Safe And Sound DM221 Speaker Replacement: 6 단계, 이미지 1/1
    • Remove the “TALK” button to get access to remove the motherboard.
  7. VTech Safe And Sound DM221 Speaker Replacement: 7 단계, 이미지 1/1
    • Push down on the antenna, located on the top of the motherboard.
  8. VTech Safe And Sound DM221 Speaker Replacement: 8 단계, 이미지 1/1
    • Gently remove the motherboard away from the monitor.
    • Be careful not to disconnect the red wire.
  9. VTech Safe And Sound DM221 Speaker Replacement: 9 단계, 이미지 1/1
    • Use the plastic spudger to push the two white plastic tabs, at the bottom of the device, up to release the metal retaining clip.
결론
Krystal
회원 가입일: 10/01/15
600 평판
안내서 5개 작성하였습니다
USF Tampa, Team 1-5, Leahy Fall 2015 USF Tampa, Team 1-5, Leahy Fall 2015 회원
USFT-LEAHY-F15S1G5
4 회원들
안내서 5개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 1
30일 전: 11
전체 시간: 340
