주요 콘텐츠로 건너뛰기
VTech Safe and Sound DM111-2 Battery Replacement
  1. VTech Safe and Sound DM111-2 Battery Replacement, Battery: 1 단계, 이미지 1개 중 1개
    • Expose the battery compartment by removing the lower back cover of the device.
    • Do this by holding the back side of the device upside down in your hands and applying pressure to the indented portion with both thumbs.
  2. VTech Safe and Sound DM111-2 Battery Replacement: 2 단계, 이미지 1개 중 1개
    • Once the batteries are exposed, use your index finger to push the battery against the spring and pull up to dislodge the battery.
    • Make sure to check for battery acid or other corrosive substances before touching the battery. If needed, use latex gloves to avoid skin irritation from battery acid.
결론
작성자
3다른 기여자 명과 함께
Darrell Griffin
회원 가입일: 08/31/15
222 평판
안내서 2개를 작성함
USF Tampa, Team 6-3, Remmell Fall 2015 USF Tampa, Team 6-3, Remmell Fall 2015 회원
USFT-REMMELL-F15S6G3
4 회원들
안내서 7개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 6
지난 30일: 22
전체 시간: 5,527
