주요 콘텐츠로 건너뛰기
VTech Safe and Sound DM111-2 Parent Unit Motherboard Replacement
필요한 것
  1. VTech Safe and Sound DM111-2 Parent Unit Motherboard Replacement, Battery: 1 단계, 이미지 1개 중 1개
    • Expose the battery compartment by removing the lower back cover of the device.
    • Do this by holding the back side of the device upside down in your hands and applying pressure to the indented portion with both thumbs.
  2. VTech Safe and Sound DM111-2 Parent Unit Motherboard Replacement: 2 단계, 이미지 1개 중 1개
    • Once the batteries are exposed, use your index finger to push the battery against the spring and pull up to dislodge the battery.
    • Make sure to check for battery acid or other corrosive substances before touching the battery. If needed, use latex gloves to avoid skin irritation from battery acid.
  3. VTech Safe and Sound DM111-2 Parent Unit Motherboard Replacement, Parent Unit Motherboard: 3 단계, 이미지 3개 중 1개 VTech Safe and Sound DM111-2 Parent Unit Motherboard Replacement, Parent Unit Motherboard: 3 단계, 이미지 3개 중 2개 VTech Safe and Sound DM111-2 Parent Unit Motherboard Replacement, Parent Unit Motherboard: 3 단계, 이미지 3개 중 3개
    • Use a plastic opening tool to gently pry along the middle of the 2 sections of the plastic housing in order to release plastic latches on the inside of the housing.
    • Do not take apart briskly or separate the two units completely as they are connected by thin wires.
  4. VTech Safe and Sound DM111-2 Parent Unit Motherboard Replacement: 4 단계, 이미지 2개 중 1개 VTech Safe and Sound DM111-2 Parent Unit Motherboard Replacement: 4 단계, 이미지 2개 중 2개
    • Gently pull apart the two housing component taking care not to damage the wire connecting them.
    • Check the wire connections from the battery compartment to the motherboard for any cuts, burn marks, or loose wires.
    • Likewise check the soldering joints for the antenna, and the power jack, and speakers, in order to make surethe issue is with the motherboard and not the wires or other components.
  5. VTech Safe and Sound DM111-2 Parent Unit Motherboard Replacement: 5 단계, 이미지 2개 중 1개 VTech Safe and Sound DM111-2 Parent Unit Motherboard Replacement: 5 단계, 이미지 2개 중 2개
    • Free the motherboard by unscrewing the two 4mm phillips head screws at the top of the motherboard
    • Flip over the motherboard and de-solder the wires connecting the speaker to the motherboard
결론
작성자
3다른 기여자 명과 함께
Jean Carlos
회원 가입일: 08/31/15
201 평판
안내서 2개를 작성함
USF Tampa, Team 6-3, Remmell Fall 2015 USF Tampa, Team 6-3, Remmell Fall 2015 회원
USFT-REMMELL-F15S6G3
4 회원들
안내서 7개를 작성함
1가이드 댓글
After changing the motherboard I can no longer get the device to link to the baby monitor
Hyrum Clark - 답글
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 4
지난 30일: 11
전체 시간: 1,483
