주요 콘텐츠로 건너뛰기
VTech Safe and Sound DM111-2 Speaker Replacement
필요한 것
  1. VTech Safe and Sound DM111-2 Speaker Replacement, Battery: 1 단계, 이미지 1개 중 1개
    • Expose the battery compartment by removing the lower back cover of the device.
    • Do this by holding the back side of the device upside down in your hands and applying pressure to the indented portion with both thumbs.
  2. VTech Safe and Sound DM111-2 Speaker Replacement: 2 단계, 이미지 1개 중 1개
    • Once the batteries are exposed, use your index finger to push the battery against the spring and pull up to dislodge the battery.
    • Make sure to check for battery acid or other corrosive substances before touching the battery. If needed, use latex gloves to avoid skin irritation from battery acid.
  3. VTech Safe and Sound DM111-2 Speaker Replacement, Speaker: 3 단계, 이미지 1개 중 1개
    • Use the Philips #0 Screwdriver to remove the two 11.2 mm screws located on either side of the battery slots.
  4. VTech Safe and Sound DM111-2 Speaker Replacement: 4 단계, 이미지 3개 중 1개 VTech Safe and Sound DM111-2 Speaker Replacement: 4 단계, 이미지 3개 중 2개 VTech Safe and Sound DM111-2 Speaker Replacement: 4 단계, 이미지 3개 중 3개
    • Use a plastic opening tool to gently disconnect the clips holding the case together.
    • Be careful when taking the case apart there are wires attached to the back case and the motherboard which should not be disconnected.
  5. VTech Safe and Sound DM111-2 Speaker Replacement: 5 단계, 이미지 2개 중 1개 VTech Safe and Sound DM111-2 Speaker Replacement: 5 단계, 이미지 2개 중 2개
    • Carefully unscrew the two 6.8 mm Philips head screws near the top of the device using the Philips#0 screw driver.
    • Be careful removing the motherboard because there will be a set of wires connecting the speaker and motherboard.
  6. VTech Safe and Sound DM111-2 Speaker Replacement: 6 단계, 이미지 1개 중 1개
    • Use a Philips#0 screwdriver and unscrew the two 6.8mm Philips screws holding the speaker in place.
  7. VTech Safe and Sound DM111-2 Speaker Replacement: 7 단계, 이미지 1개 중 1개
    • Remove the solder from the bottom left corner of the motherboard to completely detach the speaker from the device.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
Darrell Griffin
회원 가입일: 08/31/15
222 평판
안내서 2개를 작성함
USF Tampa, Team 6-3, Remmell Fall 2015 USF Tampa, Team 6-3, Remmell Fall 2015 회원
USFT-REMMELL-F15S6G3
4 회원들
안내서 7개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 3
지난 30일: 17
전체 시간: 3,732
