주요 콘텐츠로 건너뛰기
VTech Spin and Learn Color Flashlight Ladybug Button Replacement
필요한 것
  1. VTech Spin and Learn Color Flashlight Ladybug Button Replacement, Battery Housing: 1 단계, 이미지 1/2 VTech Spin and Learn Color Flashlight Ladybug Button Replacement, Battery Housing: 1 단계, 이미지 2/2
    • Locate the battery housing on the back of the flashlight as pictured.
    • Unscrew the single 8 mm Phillips #1 screw.
    • The screw will stay attached to the cover that will be removed.
    • Lift the battery housing cover to reveal the battery terminals. Remove the batteries.
  2. VTech Spin and Learn Color Flashlight Ladybug Button Replacement, Speaker Housing: 2 단계, 이미지 1/3 VTech Spin and Learn Color Flashlight Ladybug Button Replacement, Speaker Housing: 2 단계, 이미지 2/3 VTech Spin and Learn Color Flashlight Ladybug Button Replacement, Speaker Housing: 2 단계, 이미지 3/3
    • Locate the light blue speaker housing on the bottom of the flashlight.
    • Remove the three 6 mm Phillips #0 screws.
    • Once the screws have been removed, pull the housing away from the yellow body of the flashlight. Be careful not to disconnect the white wires from the speaker, unless speaker replacement is required.
  3. VTech Spin and Learn Color Flashlight Ladybug Button Replacement, Red Ring: 3 단계, 이미지 1/3 VTech Spin and Learn Color Flashlight Ladybug Button Replacement, Red Ring: 3 단계, 이미지 2/3 VTech Spin and Learn Color Flashlight Ladybug Button Replacement, Red Ring: 3 단계, 이미지 3/3
    • Locate the screw covering stickers on the side of the red ring. These two stickers will be slightly larger than the normal stickers. In this case it was a ladybug and a duck on opposite sides of the ring.
    • With a plastic opening tool, gently remove the stickers by prying around the edges. Be careful with these as you will want to reapply them later
  4. VTech Spin and Learn Color Flashlight Ladybug Button Replacement: 4 단계, 이미지 1/3 VTech Spin and Learn Color Flashlight Ladybug Button Replacement: 4 단계, 이미지 2/3 VTech Spin and Learn Color Flashlight Ladybug Button Replacement: 4 단계, 이미지 3/3
    • Remove the two 8mm Phillips #0 screws from the screw channels found under the stickers in step one. This can be seen in the first photo if step 2.
    • Once the screws have been successfully removed, grasp one half of the ring and pull gently to separate it from the yellow housing. Repeat on the opposite side and the ring is disassembled.
  5. VTech Spin and Learn Color Flashlight Ladybug Button Replacement, Main Housing: 5 단계, 이미지 1/2 VTech Spin and Learn Color Flashlight Ladybug Button Replacement, Main Housing: 5 단계, 이미지 2/2
    • Unscrew the six 8 mm Phillips #0 screws at each of the points circled in red in the first image.
    • To open, separate the two sides of the housing. They should come apart fairly easily, however you may use a spudger to pry it open. Once it's apart, it should look like the second image.
  6. VTech Spin and Learn Color Flashlight Ladybug Button Replacement, Ladybug Button: 6 단계, 이미지 1/2 VTech Spin and Learn Color Flashlight Ladybug Button Replacement, Ladybug Button: 6 단계, 이미지 2/2
    • Locate the ladybug button on the handle of the opened flashlight and remove it from its slot.
결론
Mahmoud Khalifa
회원 가입일: 08/26/15
253 평판
안내서 2개 작성하였습니다
USF Tampa, Team 2-6, Blackwell Fall 2015 USF Tampa, Team 2-6, Blackwell Fall 2015 회원
USFT-BLACKWELL-F15S2G6
3 회원들
안내서 18개 작성하였습니다
댓글 한 개
I did same thing with one of my tactical flashlight https://tacticalflashlightguide.com/ and it’s worked as well. I have changed my flashlight button without any problem.
kineeok - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 6
전체 시간: 334
