주요 콘텐츠로 건너뛰기
VTech Write and Learn Creative Center Magnetic Pen Replacement
필요한 것
  1. VTech Write and Learn Creative Center Magnetic Pen Replacement, Back Panel: 1 단계, 이미지 3개 중 1개 VTech Write and Learn Creative Center Magnetic Pen Replacement, Back Panel: 1 단계, 이미지 3개 중 2개 VTech Write and Learn Creative Center Magnetic Pen Replacement, Back Panel: 1 단계, 이미지 3개 중 3개
    • Remove all eleven 9mm PH 2 Phillips screws securing the back of the case.
  2. VTech Write and Learn Creative Center Magnetic Pen Replacement, Magnetic Pen: 2 단계, 이미지 1개 중 1개
    • If there is any hot glue, remove it from the base of the wires.
    • During reassembly, reapply the hot glue to the connections to reinforce it's strength.
  3. VTech Write and Learn Creative Center Magnetic Pen Replacement: 3 단계, 이미지 1개 중 1개
    • In order to remove the magnetic pen, you must desolder the two wires connecting it to the circuit board.
    • When you desolder, apply the tip of the soldering iron to the soldered joint for approximately 5 - 10 seconds.
    • The soldered joint will turn to a liquid consistency. At this moment, remove the wire and soldering iron.
    • Repeat each of the following steps for the second soldered joint.
    • Soldering irons are dangerously hot. The soldering iron should only come in contact with joints being desoldered or soldered.
    • Make sure to allow time for your soldering iron to heat up before using it.
    • Make sure the tip of the soldering iron is cleaned so the tin on the tip is exposed. This will allow the soldering iron to work efficiently.
  4. VTech Write and Learn Creative Center Magnetic Pen Replacement: 4 단계, 이미지 3개 중 1개 VTech Write and Learn Creative Center Magnetic Pen Replacement: 4 단계, 이미지 3개 중 2개 VTech Write and Learn Creative Center Magnetic Pen Replacement: 4 단계, 이미지 3개 중 3개
    • Undo the knot, then feed the cord from the inside of the case to the outside using the hole the company originally designed for the cord.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
2다른 기여자 명과 함께
Victoria Hathaway
회원 가입일: 04/06/16
331 평판
안내서 3개를 작성함
UMass Dartmouth, Team 1-2, Miles Spring 2016 UMass Dartmouth, Team 1-2, Miles Spring 2016 회원
UMASSD-MILES-S16S1G2
3 회원들
안내서 12개를 작성함
3가이드 댓글
Great write up. Where did you buy the replacement pen?
Jeff Donkersley - 답글
Where do you purchase the replacement pen please?
Ben Rieff - 답글
Where can I buy a replacement pen?
Simone Wisdom - 답글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 7
지난 30일: 47
전체 시간: 2,778
