주요 콘텐츠로 건너뛰기
VTech Write and Learn Creative Center Magnetic Screen Replacement
필요한 것
  1. VTech Write and Learn Creative Center Magnetic Screen Replacement, Back Panel: 1 단계, 이미지 1/3 VTech Write and Learn Creative Center Magnetic Screen Replacement, Back Panel: 1 단계, 이미지 2/3 VTech Write and Learn Creative Center Magnetic Screen Replacement, Back Panel: 1 단계, 이미지 3/3
    • Remove all eleven 9mm PH 2 Phillips screws securing the back of the case.
  2. VTech Write and Learn Creative Center Magnetic Screen Replacement, Slider: 2 단계, 이미지 1/1
    • Remove the two 7mm PH 0 Phillips screws holding the slider to the slider handle.
    • The back of the slider will likely be coated in lubricant. Be careful not to make a mess.
  3. VTech Write and Learn Creative Center Magnetic Screen Replacement, Magnetic Screen: 3 단계, 이미지 1/2 VTech Write and Learn Creative Center Magnetic Screen Replacement, Magnetic Screen: 3 단계, 이미지 2/2
    • Remove the four 5mm PH 0 Phillips screws with 7mm heads holding the screen to the front of the case.
  4. VTech Write and Learn Creative Center Magnetic Screen Replacement: 4 단계, 이미지 1/1
    • Gently push the edges of the screen to remove it from the front case.
결론
Philip Zietkowski
회원 가입일: 03/25/16
342 평판
안내서 2개 작성하였습니다
UMass Dartmouth, Team 1-2, Miles Spring 2016 UMass Dartmouth, Team 1-2, Miles Spring 2016 회원
UMASSD-MILES-S16S1G2
3 회원들
안내서 12개 작성하였습니다
댓글 2개
Thank you for this! Do you have suggestions on how to fix the magnetic screen or get a replacement? I emailed the manufacturer (B. Toys for mine) and unfortunately they replied, “​We replace the full toy only, and do not offer the internal parts as replacements.“ But I don’t want all the rest of the plastic - I just want the magnets on the screen to properly appear and disappear. Instead, its like the magnetic powder floats so it’s constantly grey rather than clear or magnetized.
Katie - 답글
Hello I got the same issue i dont know how to fix ot of you mine is not even an year old but still get that grey screen plz help n let me know how to get rid of it Thankyou
wings_latif -
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 20
전체 시간: 1,379
