주요 콘텐츠로 건너뛰기
VTech Write and Learn Creative Center Speaker Replacement
필요한 것
  1. VTech Write and Learn Creative Center Speaker Replacement, Back Panel: 1 단계, 이미지 3개 중 1개 VTech Write and Learn Creative Center Speaker Replacement, Back Panel: 1 단계, 이미지 3개 중 2개 VTech Write and Learn Creative Center Speaker Replacement, Back Panel: 1 단계, 이미지 3개 중 3개
    • Remove all eleven 9mm PH 2 Phillips screws securing the back of the case.
  2. VTech Write and Learn Creative Center Speaker Replacement, Speaker: 2 단계, 이미지 3개 중 1개 VTech Write and Learn Creative Center Speaker Replacement, Speaker: 2 단계, 이미지 3개 중 2개 VTech Write and Learn Creative Center Speaker Replacement, Speaker: 2 단계, 이미지 3개 중 3개
    • In order to remove the speaker, you must desolder the two wires connecting it to the circuit board.
    • When you desolder, apply the tip of the soldering iron to the soldered joint for approximately 5 - 10 seconds.
    • The soldered joint will turn to a liquid consistency. At this moment, remove the wire and soldering iron.
    • Repeat each of the following steps for the second soldered joint.
    • Soldering irons are dangerously hot. The soldering iron should only come in contact with joints being desoldered or soldered.
    • Make sure to allow time for your soldering iron to heat up before using it.
    • Make sure the tip of the soldering iron is cleaned so the tin on the tip is exposed. This will allow the soldering iron to work efficiently.
  3. VTech Write and Learn Creative Center Speaker Replacement: 3 단계, 이미지 2개 중 1개 VTech Write and Learn Creative Center Speaker Replacement: 3 단계, 이미지 2개 중 2개
    • Remove the 2 5mm PH 0 Phillips screws with 10 mm heads that secure the speaker to the front of the case.
결론
작성자
3다른 기여자 명과 함께
Victoria Hathaway
회원 가입일: 04/06/16
331 평판
안내서 3개를 작성함
UMass Dartmouth, Team 1-2, Miles Spring 2016 UMass Dartmouth, Team 1-2, Miles Spring 2016 회원
UMASSD-MILES-S16S1G2
3 회원들
안내서 12개를 작성함
1가이드 댓글
Where can I buy the speaker
Lesa Thomas - 답글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 6
지난 30일: 17
전체 시간: 1,363
