주요 콘텐츠로 건너뛰기
VTechCS6719-16 Ringer Replacment
필요한 것
  1. VTechCS6719-16 Ringer Replacment, Ringer: 1 단계, 이미지 1개 중 1개
    • Remove sliding back cover from case.
  2. VTechCS6719-16 Ringer Replacment: 2 단계, 이미지 1개 중 1개
    • Lift the battery and unplug the two pin cable from phone base.
  3. VTechCS6719-16 Ringer Replacment: 3 단계, 이미지 1개 중 1개
    • Slide back cover off the phone
    • Located at the bottom of the frame are the two-10 mm screws.
    • Use a Phillips head screwdriver to remove both 10 mm screws.
    • It is recommended to use a magnetic mat or place the screws on an easy to see surface. They will be needed when the phone is reassembled.
  4. VTechCS6719-16 Ringer Replacment: 4 단계, 이미지 1개 중 1개
    • After removing the two screws from the back of the phone carefully use the metal spudger to lift along the edges and raise the phone case from the internal clips.
  5. VTechCS6719-16 Ringer Replacment: 5 단계, 이미지 1개 중 1개
    • Once the case is lifted, the board should be freed except for the connection between the ringer and the case.
    • Be careful do not pull the case away from the phone in a jerking or aggressive motion.
  6. VTechCS6719-16 Ringer Replacment: 6 단계, 이미지 1개 중 1개
    • Using the spudger lift the latch over the ringer to release it.
    • When working with electronics, it's important to choose a tool that's ESD-safe to avoid accidental damage to the device. The metal spudger is great when you need serious prying power, but the regular black nylon spudger should be used whenever possible.
  7. VTechCS6719-16 Ringer Replacment: 7 단계, 이미지 1개 중 1개
    • The last component of the latch is soldered to the circuit board. This will take some soldering expertise.
결론
작성자
3다른 기여자 명과 함께
Charles montes
회원 가입일: 10/20/16
513 평판
안내서 5개를 작성함
UMass Dartmouth, Team 5-5, Martin Fall 2016 UMass Dartmouth, Team 5-5, Martin Fall 2016 회원
UMASSD-MARTIN-F16S5G5
3 회원들
안내서 10개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 1
지난 30일: 7
전체 시간: 297
