소개
Follow this guide to replace the hand strap or adjustment strap on the left-hand controller for a Valve Index VR headset.
Power off your headset and controllers before you begin your repair.
Note: The photos used in this guide are of the right-hand controller, but the process is exactly the same.
필요한 것
Press and hold the elastic band adjustment button.
Slide the elastic band out of the controller.
Insert an opening pick under the round plastic cover next to the A and B buttons.
Slide the opening pick around the top of the controller until all three plastic clips are disengaged.
Use a T5 Torx screwdriver to remove the two 6.1 mm screws securing the adjustment strap to the controller.
Once the adjustment strap is unscrewed, the spring underneath may fall out.
Slide the adjustment strap out from the controller to remove it.
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Valve Index Answers community for help.
다른 3명이 해당 안내서를 완성하였습니다.
댓글 3개
Doesn't explain how to put it back together with the spring which is conveniently missing from the photos.
I'm several months late, but just in case I figured I'd toss a reply just in case you were interested in the imgur guide I made to help out anyone else struggling with this. It's posted as a separate comment on this post. Hope your repair went well otherwise!
I appreciate the guide, but as someone noted above, you are seriously lacking in the spring instructions, which might be the most important part of this assembly. However, I managed to find a way to get the spring seated back in on my own, and so for any other unfortunates stumbling onto this guide, I made my own crappy Imgur gallery guide for re-seating the spring. Each image has a small paragraph beneath it explaining the steps to take. I hope it manages to help anyone else struggling to swap out a strap.
(NOTE: Images were made for Right hand controller, simply mirror for Left hand.)
https://imgur.com/gallery/RQYtS5e
