주요 콘텐츠로 건너뛰기
Valve Index Headset Motherboard Replacement
필요한 것
  1. Valve Index Headset Motherboard Replacement, Remove the front cover: 1 단계, 이미지 1/2 Valve Index Headset Motherboard Replacement, Remove the front cover: 1 단계, 이미지 2/2
    • Use your hand to pull the front cover straight off of the front of the headset.
    • The front cover is held in place by four magnets that secure to screws in the motherboard cover.
    • Before installing a front cover, ensure the four screws securing the motherboard cover are installed. Otherwise, the front cover will not stay in place.
  2. Valve Index Headset Motherboard Replacement, Remove the motherboard cover: 2 단계, 이미지 1/1
    • Use a T5 Torx screwdriver to remove the four 5.4 mm screws securing the motherboard cover to the headset.
  3. Valve Index Headset Motherboard Replacement: 3 단계, 이미지 1/2 Valve Index Headset Motherboard Replacement: 3 단계, 이미지 2/2
    • Remove the motherboard cover from the headset.
  4. Valve Index Headset Motherboard Replacement, Remove the front fascia: 4 단계, 이미지 1/1
    • Use a T5 Torx screwdriver to remove the following eight screws from the front fascia:
    • Four 6.3 mm screws with fine threads
    • Four 6.0 mm screws with coarse threads
  5. Valve Index Headset Motherboard Replacement: 5 단계, 이미지 1/3 Valve Index Headset Motherboard Replacement: 5 단계, 이미지 2/3 Valve Index Headset Motherboard Replacement: 5 단계, 이미지 3/3
    • Use a spudger to unlock the ZIF connector at the top-left corner of the motherboard.
    • Disconnect the FPC ribbon cable from the motherboard.
  6. Valve Index Headset Motherboard Replacement: 6 단계, 이미지 1/3 Valve Index Headset Motherboard Replacement: 6 단계, 이미지 2/3 Valve Index Headset Motherboard Replacement: 6 단계, 이미지 3/3
    • Use a spudger to unlock the ZIF connector at the top-right corner of the motherboard.
    • Disconnect the FPC ribbon cable.
  7. Valve Index Headset Motherboard Replacement: 7 단계, 이미지 1/2 Valve Index Headset Motherboard Replacement: 7 단계, 이미지 2/2
    • Use the flat end of a spudger to disconnect the press connector from the bottom-left corner of the motherboard.
    • To re-attach press connectors like this one, carefully align and press down on one side until it clicks into place, then repeat on the other side. Do not press down on the middle. If the connector is misaligned, the pins can bend, causing permanent damage.
  8. Valve Index Headset Motherboard Replacement: 8 단계, 이미지 1/2 Valve Index Headset Motherboard Replacement: 8 단계, 이미지 2/2
    • Use the flat end of a spudger to disconnect the press connector from the bottom-right corner of the motherboard.
  9. Valve Index Headset Motherboard Replacement: 9 단계, 이미지 1/2 Valve Index Headset Motherboard Replacement: 9 단계, 이미지 2/2
    • Insert an opening pick in between the front fascia and the headset.
    • Slide the opening pick over to separate the front fascia from the headset.
  10. Valve Index Headset Motherboard Replacement: 10 단계, 이미지 1/2 Valve Index Headset Motherboard Replacement: 10 단계, 이미지 2/2
    • Continue sliding the opening pick along the perimeter of the front fascia until all edges are free.
  11. Valve Index Headset Motherboard Replacement: 11 단계, 이미지 1/2 Valve Index Headset Motherboard Replacement: 11 단계, 이미지 2/2
    • Remove the front fascia.
  12. Valve Index Headset Motherboard Replacement, Remove the motherboard: 12 단계, 이미지 1/1
    • Note the seven cables that must be disconnected in the following steps before the motherboard can be removed.
  13. Valve Index Headset Motherboard Replacement: 13 단계, 이미지 1/3 Valve Index Headset Motherboard Replacement: 13 단계, 이미지 2/3 Valve Index Headset Motherboard Replacement: 13 단계, 이미지 3/3
    • Use the flat end of a spudger to unlock the wide ZIF connector on the left side of the motherboard.
  14. Valve Index Headset Motherboard Replacement: 14 단계, 이미지 1/2 Valve Index Headset Motherboard Replacement: 14 단계, 이미지 2/2
    • Use the flat end of a spudger to disconnect the press connector near the bottom-left edge of the motherboard.
    • During reassembly, be sure this cable is not trapped underneath the motherboard.
  15. Valve Index Headset Motherboard Replacement: 15 단계, 이미지 1/3 Valve Index Headset Motherboard Replacement: 15 단계, 이미지 2/3 Valve Index Headset Motherboard Replacement: 15 단계, 이미지 3/3
    • Use your finger or an opening tool to unlock the display cable connector at the top of the motherboard.
    • Carefully disconnect the display cable connector.
  16. Valve Index Headset Motherboard Replacement: 16 단계, 이미지 1/2 Valve Index Headset Motherboard Replacement: 16 단계, 이미지 2/2
    • Use the pointed end of a spudger to gently disconnect the bundled cable connector from the top-right corner of the motherboard.
  17. Valve Index Headset Motherboard Replacement: 17 단계, 이미지 1/3 Valve Index Headset Motherboard Replacement: 17 단계, 이미지 2/3 Valve Index Headset Motherboard Replacement: 17 단계, 이미지 3/3
    • Use the pointed end of a spudger to unlock the ZIF connector next to the USB port on the motherboard.
    • Disconnect the FPC cable from the motherboard.
    • During reassembly, make sure this ribbon cable is not trapped under the motherboard.
  18. Valve Index Headset Motherboard Replacement: 18 단계, 이미지 1/2 Valve Index Headset Motherboard Replacement: 18 단계, 이미지 2/2
    • Use the flat end of a spudger to disconnect the press connector below the USB port on the motherboard.
    • During reassembly, make sure this cable is not trapped under the motherboard.
  19. Valve Index Headset Motherboard Replacement: 19 단계, 이미지 1/3 Valve Index Headset Motherboard Replacement: 19 단계, 이미지 2/3 Valve Index Headset Motherboard Replacement: 19 단계, 이미지 3/3
    • Use a spudger to unlock the wide ZIF connector near the right edge of the motherboard.
  20. Valve Index Headset Motherboard Replacement: 20 단계, 이미지 1/1
    • Use a T5 Torx screwdriver to remove the five 6.0 mm screws securing the motherboard to the headset.
  21. Valve Index Headset Motherboard Replacement: 21 단계, 이미지 1/2 Valve Index Headset Motherboard Replacement: 21 단계, 이미지 2/2
    • Grab the motherboard by the USB port and carefully remove it from the headset.
    • During reassembly, be very careful not to trap any of the previously disconnected cables under the motherboard.
결론
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Valve Index Answers community for help.
다른 한 분이 해당 안내서를 완성하였습니다.
Sam Omiotek
회원 가입일: 02/25/19
73,702 평판
안내서 288개 작성하였습니다
댓글 5개
Where can I buy the motherboard? It doesn't look like ifixit has them.
Curtis Gray - 답글
I have this same question.
Patrick Hartge -
you would think the replacement motherboard would be in the list of required items. Where are you supposed to buy this from?
Grant Za - 답글
Same question ,where do i get a replacement main board
Gifted Misfit - 답글
Daniel O'Sullivan - 답글
댓글 쓰기
조회 통계:
24 시간 전: 8
7일 전: 43
30일 전: 216
전체 시간: 8,487
