주요 콘텐츠로 건너뛰기
Valve Index Headset Tether and Trident Cable Replacement
필요한 것
  1. Valve Index Headset Tether and Trident Cable Replacement, Remove the face gasket: 1 단계, 이미지 1/2 Valve Index Headset Tether and Trident Cable Replacement, Remove the face gasket: 1 단계, 이미지 2/2
    • Use your hand to gently pull the face gasket straight off of the headset.
    • The face gasket is held in place by four magnets that secure to screws in the face bezel.
    • Before installing a face gasket, ensure the four screws securing the face gasket bezel are installed. Otherwise, the face gasket will not stay in place.
  2. Valve Index Headset Tether and Trident Cable Replacement, Remove the head strap clip: 2 단계, 이미지 1/3 Valve Index Headset Tether and Trident Cable Replacement, Remove the head strap clip: 2 단계, 이미지 2/3 Valve Index Headset Tether and Trident Cable Replacement, Remove the head strap clip: 2 단계, 이미지 3/3
    • Insert the flat end of a spudger in between the bottom of the head strap clip and the head strap padding.
    • Pry up on the head strap clip until it is unclipped from the head strap.
    • To reinstall, first locate the recesses on the head strap for mounting the clip. Next, align the clip with the recesses, verify the tether cable is threaded through the clip, then simply press the clip back into place.
  3. Valve Index Headset Tether and Trident Cable Replacement, Separate the cable from the head strap guide: 3 단계, 이미지 1/2 Valve Index Headset Tether and Trident Cable Replacement, Separate the cable from the head strap guide: 3 단계, 이미지 2/2
    • Use your fingers to pull the tether cable straight up off of the head strap cable guide.
  4. Valve Index Headset Tether and Trident Cable Replacement, Disconnect the tether cable: 4 단계, 이미지 1/2 Valve Index Headset Tether and Trident Cable Replacement, Disconnect the tether cable: 4 단계, 이미지 2/2
    • Pull the tether cable straight back out of the headset.
결론
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Valve Index Answers community for help.
다른 11명이 해당 안내서를 완성하였습니다.
Sam Omiotek
회원 가입일: 02/25/19
73,429 평판
안내서 288개 작성하였습니다
댓글 한 개
"übersetzer:innen" danke. das erste und letzte mal was gelesen hier.
blub blub - 답글
댓글 쓰기
조회 통계:
24 시간 전: 16
7일 전: 134
30일 전: 832
전체 시간: 27,198
