주요 콘텐츠로 건너뛰기
Valve Index Headset Tether and Trident Cable Replacement
필요한 것
  1. Valve Index Headset Tether and Trident Cable Replacement, Remove the face gasket: 1 단계, 이미지 2개 중 1개 Valve Index Headset Tether and Trident Cable Replacement, Remove the face gasket: 1 단계, 이미지 2개 중 2개
    • Use your hand to gently pull the face gasket straight off of the headset.
    • The face gasket is held in place by four magnets that secure to screws in the face bezel.
    • Before installing a face gasket, ensure the four screws securing the face gasket bezel are installed. Otherwise, the face gasket will not stay in place.
  2. Valve Index Headset Tether and Trident Cable Replacement, Remove the head strap clip: 2 단계, 이미지 3개 중 1개 Valve Index Headset Tether and Trident Cable Replacement, Remove the head strap clip: 2 단계, 이미지 3개 중 2개 Valve Index Headset Tether and Trident Cable Replacement, Remove the head strap clip: 2 단계, 이미지 3개 중 3개
    • Insert the flat end of a spudger in between the bottom of the head strap clip and the head strap padding.
    • Pry up on the head strap clip until it is unclipped from the head strap.
    • To reinstall, first locate the recesses on the head strap for mounting the clip. Next, align the clip with the recesses, verify the tether cable is threaded through the clip, then simply press the clip back into place.
  3. Valve Index Headset Tether and Trident Cable Replacement, Separate the cable from the head strap guide: 3 단계, 이미지 2개 중 1개 Valve Index Headset Tether and Trident Cable Replacement, Separate the cable from the head strap guide: 3 단계, 이미지 2개 중 2개
    • Use your fingers to pull the tether cable straight up off of the head strap cable guide.
  4. Valve Index Headset Tether and Trident Cable Replacement, Disconnect the tether cable: 4 단계, 이미지 2개 중 1개 Valve Index Headset Tether and Trident Cable Replacement, Disconnect the tether cable: 4 단계, 이미지 2개 중 2개
    • Pull the tether cable straight back out of the headset.
결론
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Valve Index Answers community for help.
다른 15명이 해당 안내서를 완성하였습니다.
작성자
1다른 기여자 명과 함께
Sam Omiotek
회원 가입일: 02/25/19
92,557 평판
안내서 290개를 작성함
3가이드 댓글
"übersetzer:innen" danke. das erste und letzte mal was gelesen hier.
blub blub - 답글
Thanks, the clip was giving me problems and this gave me the confidence that I was on the right path. :D
William Wilkins - 답글
Again this autor doesn't understand the meaning of replacing, he just shows us how to dismantle the headset, not how to reinstall it correctly. Useless guide...
Jason Bouchard - 답글
댓글 쓰기
조회 통계:
지난 24시간: 9
지난 7일: 86
지난 30일: 535
전체 시간: 39,994
