주요 콘텐츠로 건너뛰기
Vanmoof No 3 Replacement Mudguards
  1. Vanmoof No 3  Replacement Mudguards, Get the Mudguards: 1 단계, 이미지 1개 중 1개
    • Make sure you get 2 mudguards, one set of stays that are straight for the rear, and a second that have a bend. Also make sure you have the two rear connection pieces.
  2. Vanmoof No 3  Replacement Mudguards, The problem: 2 단계, 이미지 1개 중 1개
    • You need to cut both sides of the mudguard so it can fit between the chain stays, and drill a new hole to attach to the bottom of the frame.
  3. Vanmoof No 3  Replacement Mudguards, Cut the rear mudguard: 3 단계, 이미지 3개 중 1개 Vanmoof No 3  Replacement Mudguards, Cut the rear mudguard: 3 단계, 이미지 3개 중 2개 Vanmoof No 3  Replacement Mudguards, Cut the rear mudguard: 3 단계, 이미지 3개 중 3개
    • The rear mudguard will need to be cut at the front.
    • First cut at parallel to the bottom about 16mm long
    • Second cut is 7mm in from the rounded edge
  4. Vanmoof No 3  Replacement Mudguards, Bend over the metal to make the edge: 4 단계, 이미지 3개 중 1개 Vanmoof No 3  Replacement Mudguards, Bend over the metal to make the edge: 4 단계, 이미지 3개 중 2개 Vanmoof No 3  Replacement Mudguards, Bend over the metal to make the edge: 4 단계, 이미지 3개 중 3개
    • Bend the edges over so you make a rounded lip
  5. Vanmoof No 3  Replacement Mudguards, Drill the new hole: 5 단계, 이미지 1개 중 1개
    • Drill the frame attachment hole
    • Bolt to the frame
결론
작성자
2다른 기여자 명과 함께
Martin Hampton
회원 가입일: 02/13/16
1,308 평판
안내서 7개를 작성함
댓글 0개
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 3
지난 30일: 18
전체 시간: 990
