주요 콘텐츠로 건너뛰기
Varmilo MA87M Love Birds Switch Replacement
필요한 것
  1. Varmilo MA87M Love Birds Switch Replacement, Switch: 1 단계, 이미지 3개 중 1개 Varmilo MA87M Love Birds Switch Replacement, Switch: 1 단계, 이미지 3개 중 2개 Varmilo MA87M Love Birds Switch Replacement, Switch: 1 단계, 이미지 3개 중 3개
    • Take the key removal tool and push down on the key until the tool clicks into place.
    • Pull up with the tool to remove the keycaps.
    • When the keycaps are removed they can be cleaned at this time.
    • Make sure the keyboard is disconnected from the computer or the computer is turned off during this process.
  2. Varmilo MA87M Love Birds Switch Replacement: 2 단계, 이미지 2개 중 1개 Varmilo MA87M Love Birds Switch Replacement: 2 단계, 이미지 2개 중 2개
    • Remove the switches from the keyboard by aligning the keyboard remover along the groves at the bottom of the switch.
    • Use caution; if you damage a switch, you will need to replace it.
  3. Varmilo MA87M Love Birds Switch Replacement: 3 단계, 이미지 1개 중 1개
    • Insert the new switch into the empty slot where the old switch was and push down on the new switch.
  4. Varmilo MA87M Love Birds Switch Replacement: 4 단계, 이미지 2개 중 1개 Varmilo MA87M Love Birds Switch Replacement: 4 단계, 이미지 2개 중 2개
    • When the new switch is inserted, the keycap can be slotted on and pushed easily back into place.
결론
작성자
5다른 기여자 명과 함께
Josue Vargas Sena
회원 가입일: 10/25/23
235 평판
안내서 2개를 작성함
Team Jansport Team Jansport 회원
Community
1 회원
안내서 3개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 7
지난 30일: 46
전체 시간: 501
