주요 콘텐츠로 건너뛰기
Velocity Micro Cruz Battery Replacement
필요한 것
  1. Velocity Micro Cruz Battery Replacement, Battery: 1 단계, 이미지 1개 중 1개
    • Insert a plastic opening device into the small crack separating the screen and the back of the device.
    • After the back of the device is separated, remove the back and you can now access the battery.
    • When prying the back of the device off, be careful as this could cause small damages or cracks to the screen.
  2. Velocity Micro Cruz Battery Replacement: 2 단계, 이미지 1개 중 1개
    • The battery is connected to the motherboard where the picture indicates.
    • To remove the battery, you must first detach the battery wire connecting it from the motherboard. To do this, simply gently, but firmly, pull it out of the motherboard connector.
  3. Velocity Micro Cruz Battery Replacement: 3 단계, 이미지 1개 중 1개
    • Simply pry the battery out of the device at this point. The battery may be held in place by adhesive glue and require a nylon spudger or plastic opening tool to help pry it out.
    • Place your new battery in place of the old one. Connect the new battery's wire to the motherboard and you are finished.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
2다른 기여자 명과 함께
Hunter Ralston
회원 가입일: 10/10/16
122 평판
안내서 1개를 작성함
Texas Tech, Team 12-4, Bennett Fall 2016 Texas Tech, Team 12-4, Bennett Fall 2016 회원
TTU-BENNETT-F16S12G4
4 회원들
안내서 2개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 1
지난 30일: 6
전체 시간: 1,228
