주요 콘텐츠로 건너뛰기
Velocity Micro Cruz T301 Motherboard Replacement
필요한 것
  1. Velocity Micro Cruz T301 Motherboard  Replacement, Motherboard: 1 단계, 이미지 1/1
    • Insert the plastic opening tool in the SD port. The edge point should be pointed towards the rear panel.
  2. Velocity Micro Cruz T301 Motherboard  Replacement: 2 단계, 이미지 1/1
    • Insert a small opening tool between the rear panel and the tablet.
  3. Velocity Micro Cruz T301 Motherboard  Replacement: 3 단계, 이미지 1/1
    • The large opening tool is not needed any more.
  4. Velocity Micro Cruz T301 Motherboard  Replacement: 4 단계, 이미지 1/2 Velocity Micro Cruz T301 Motherboard  Replacement: 4 단계, 이미지 2/2
    • Move the small tool opener around the rear panel to free the 12 edges.
  5. Velocity Micro Cruz T301 Motherboard  Replacement: 5 단계, 이미지 1/1
    • Using PH0 Phillips Driver, remove the 4 Screws in the Metal part.
  6. Velocity Micro Cruz T301 Motherboard  Replacement: 6 단계, 이미지 1/1
    • Using a plastic Spudger remove the battery connector.
  7. Velocity Micro Cruz T301 Motherboard  Replacement: 7 단계, 이미지 1/1
    • Using PH0 Phillips Driver, remove the 12 Screws in the cover.
  8. Velocity Micro Cruz T301 Motherboard  Replacement: 8 단계, 이미지 1/1
    • Place a metal Spudger between the tablet and the back cover.
  9. Velocity Micro Cruz T301 Motherboard  Replacement: 9 단계, 이미지 1/1
    • Move the spudger around the tablet to release the clips attached to the tablet.
  10. Velocity Micro Cruz T301 Motherboard  Replacement: 10 단계, 이미지 1/1
    • Use a plastic spudger to release the connection between the speakers and the motherboard as shown in the picture.
  11. Velocity Micro Cruz T301 Motherboard  Replacement: 11 단계, 이미지 1/1
    • This guide shows the use of incorrect tools. Always use ESD safe tools when dealing with delicate internal components.
    • Use a nylon spudger to remove the top plug connector from the motherboard.
  12. Velocity Micro Cruz T301 Motherboard  Replacement: 12 단계, 이미지 1/2 Velocity Micro Cruz T301 Motherboard  Replacement: 12 단계, 이미지 2/2
    • Use a metal spudger to remove both screen cable connectors
  13. Velocity Micro Cruz T301 Motherboard  Replacement: 13 단계, 이미지 1/1
    • use openning tools to remove the motherboard.
결론
Ahmed
회원 가입일: 10/05/16
227 평판
안내서 1개 작성함
USF Tampa, Team 1-6, Cagle Fall 2016 USF Tampa, Team 1-6, Cagle Fall 2016 회원
USFT-CAGLE-F16S1G6
3 회원들
안내서 5개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 7
전체 시간: 183
