주요 콘텐츠로 건너뛰기
Velocity Micro Cruz T301 Speakers Replacement
필요한 것
  1. Velocity Micro Cruz T301 Speakers Replacement, Speakers: 1 단계, 이미지 1/1
    • Insert an opening tool in the SD port, with the edge pointing towards the rear panel.
    • Use the opening tool to pry the back plate up.
  2. Velocity Micro Cruz T301 Speakers Replacement: 2 단계, 이미지 1/1
    • Insert a second opening tool into the space created by the first opening tool.
  3. Velocity Micro Cruz T301 Speakers Replacement: 3 단계, 이미지 1/1
    • Remove the first opening tool.
  4. Velocity Micro Cruz T301 Speakers Replacement: 4 단계, 이미지 1/2 Velocity Micro Cruz T301 Speakers Replacement: 4 단계, 이미지 2/2
    • Slide the opening tool across the back plate to disconnect the clips joining the plate to the tablet.
  5. Velocity Micro Cruz T301 Speakers Replacement: 5 단계, 이미지 1/1
    • Remove the four screws in the metal plate covering the battery using a Phillips #0 screwdriver.
  6. Velocity Micro Cruz T301 Speakers Replacement: 6 단계, 이미지 1/1
    • Using a plastic spudger to remove the battery connector.
    • Failure to follow this step may result in an electric shock.
  7. Velocity Micro Cruz T301 Speakers Replacement: 7 단계, 이미지 1/1
    • Remove the battery with a spudger.
    • The photos in this guide use a metal spudger. Do not use a metal spudger as it can damage the device or conduct electricity causing a shock.
  8. Velocity Micro Cruz T301 Speakers Replacement: 8 단계, 이미지 1/1
    • Remove the twelve screws in the cover with a Phillips #0 screwdriver.
  9. Velocity Micro Cruz T301 Speakers Replacement: 9 단계, 이미지 1/1
    • Place a spudger between the tablet base and the screen.
    • Again this photo shows the use of a metal spudger. The use of a metal spudger can cause damage to the device and can lead to an electric shock.
  10. Velocity Micro Cruz T301 Speakers Replacement: 10 단계, 이미지 1/1
    • Move the spudger around the face to release the clips attached to the tablet base.
  11. Velocity Micro Cruz T301 Speakers Replacement: 11 단계, 이미지 1/1
    • Locate the speaker on the motherboard. Use the plastic spudger to disconnect the speaker from the connection port.
    • Plug the new speaker into the port, then use the plastic spudger to gently push it in.
결론
Ali Rashid Al Araimi
회원 가입일: 10/05/16
371 평판
안내서 3개 작성하였습니다
USF Tampa, Team 1-6, Cagle Fall 2016 USF Tampa, Team 1-6, Cagle Fall 2016 회원
USFT-CAGLE-F16S1G6
3 회원들
안내서 5개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 9
전체 시간: 124
