소개
In this guide you will remove a total of three pieces to replace the keyboard. It will be a combination of prying and pulling to complete the task. During this process, it would be a good idea to have some electrical cleaner handy to clean the connections and the plastic pieces of all unwanted residue. This is an easy replacement and can be done within an hour. The only tools needed will be a spudger.
  1. Place the notebook on the table, with the battery facing away from you. Slide the switch from "lock" to "unlock" with your right hand on the right side of the computer.
    • Place the notebook on the table, with the battery facing away from you.
    • Slide the switch from "lock" to "unlock" with your right hand on the right side of the computer.
    • Maintain holding the right switch in the "unlock" position.
    • Use your left hand to slide the left switch from "lock" to "unlock".
  2. Maintain both left and right switches in the "unlock" position. Use your forefingers to push the battery out of the computer.
    • Maintain both left and right switches in the "unlock" position.
    • Use your forefingers to push the battery out of the computer.
  3. US$100 이상 또는 Pro Tech Toolkit을 포함한 모든 주문의 배송은 무료입니다!
    상점 둘러보기
  4. Place the laptop fully opened with the keyboard facing upwards.
    • Place the laptop fully opened with the keyboard facing upwards.
    • Remove the hinge cover by wedging the spudger underneath at the bottom edge and gently prying upwards while sliding the spudger along the cover.
  5. Carefully remove the keyboard by lifting the top of the keyboard closest to the screen.
    • Carefully remove the keyboard by lifting the top of the keyboard closest to the screen.
    • Pull the keyboard away from the mousepad.
    • Be careful to not damage the ribbon underneath the keyboard that connects the keyboard to the computer during removal.
  6. Wedge the spudger between the plastic clamp that holds the ribbon in place and carefully pry the connector off.
    • Wedge the spudger between the plastic clamp that holds the ribbon in place and carefully pry the connector off.
결론
Sam Middleton
회원 가입일: 2013년 10월 01일
401 평판
안내서 4개 작성하였습니다
Cal Poly, Team 14-9, Forte Fall 2013 Cal Poly, Team 14-9, Forte Fall 2013 회원
CPSU-FORTE-F13S14G9
5 회원들
안내서 6개 작성하였습니다
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 1
지난 30일: 3
전체 시간: 381
