주요 콘텐츠로 건너뛰기
Velocity NoteMagix M10 A82 Keyboard Replacement
필요한 것
  1. Velocity NoteMagix M10 A82 Keyboard Replacement, Battery: 1 단계, 이미지 2개 중 1개 Velocity NoteMagix M10 A82 Keyboard Replacement, Battery: 1 단계, 이미지 2개 중 2개
    • Place the notebook on the table, with the battery facing away from you.
    • Slide the switch from "lock" to "unlock" with your right hand on the right side of the computer.
    • Maintain holding the right switch in the "unlock" position.
    • Use your left hand to slide the left switch from "lock" to "unlock".
  2. Velocity NoteMagix M10 A82 Keyboard Replacement: 2 단계, 이미지 2개 중 1개 Velocity NoteMagix M10 A82 Keyboard Replacement: 2 단계, 이미지 2개 중 2개
    • Maintain both left and right switches in the "unlock" position.
    • Use your forefingers to push the battery out of the computer.
  3. Velocity NoteMagix M10 A82 Keyboard Replacement, Keyboard: 3 단계, 이미지 1개 중 1개
    • Place the laptop fully opened with the keyboard facing upwards.
    • Remove the hinge cover by wedging the spudger underneath at the bottom edge and gently prying upwards while sliding the spudger along the cover.
  4. Velocity NoteMagix M10 A82 Keyboard Replacement: 4 단계, 이미지 1개 중 1개
    • Carefully remove the keyboard by lifting the top of the keyboard closest to the screen.
    • Pull the keyboard away from the mousepad.
    • Be careful to not damage the ribbon underneath the keyboard that connects the keyboard to the computer during removal.
  5. Velocity NoteMagix M10 A82 Keyboard Replacement: 5 단계, 이미지 1개 중 1개
    • Wedge the spudger between the plastic clamp that holds the ribbon in place and carefully pry the connector off.
결론
작성자
6다른 기여자 명과 함께
Sam Middleton
회원 가입일: 10/01/13
401 평판
안내서 4개를 작성함
Cal Poly, Team 14-9, Forte Fall 2013 Cal Poly, Team 14-9, Forte Fall 2013 회원
CPSU-FORTE-F13S14G9
5 회원들
안내서 6개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 2
지난 30일: 8
전체 시간: 636
