주요 콘텐츠로 건너뛰기
Venturer CR20 Speaker Replacement
필요한 것
  1. Venturer CR20 Speaker Replacement, Front Screen: 1 단계, 이미지 1개 중 1개
    • On the bottom of the clock locate and unscrew the single 2mm Phillips screw from bottom of the clock.
  2. Venturer CR20 Speaker Replacement: 2 단계, 이미지 2개 중 1개 Venturer CR20 Speaker Replacement: 2 단계, 이미지 2개 중 2개
    • Using a moderate amount of force, position the screwdriver in the crack between the front screen and the main body of the clock (as shown) and push the screen away from the main body of the clock.
  3. Venturer CR20 Speaker Replacement, Power Cord: 3 단계, 이미지 2개 중 1개 Venturer CR20 Speaker Replacement, Power Cord: 3 단계, 이미지 2개 중 2개
    • Get a firm grip on the outside of the clock and a firm grip on the hardware on the inside of the the clock like so and pull the hardware out from the outside of the clock.
  4. Venturer CR20 Speaker Replacement: 4 단계, 이미지 3개 중 1개 Venturer CR20 Speaker Replacement: 4 단계, 이미지 3개 중 2개 Venturer CR20 Speaker Replacement: 4 단계, 이미지 3개 중 3개
    • Using your fingers, pull the power cord connector, outlined in the picture with a red rectangle straight up to disconnect from the alarm clock.
  5. Venturer CR20 Speaker Replacement, Tuner Wheel: 5 단계, 이미지 1개 중 1개
    • Just as before, pull the speaker plug directly up to remove the plug from the motherboard.
  6. Venturer CR20 Speaker Replacement: 6 단계, 이미지 2개 중 1개 Venturer CR20 Speaker Replacement: 6 단계, 이미지 2개 중 2개
    • Applying a bit of pressure at each of the contact points (illustrated by red circles), disconnect the display from the plastic housing.
  7. Venturer CR20 Speaker Replacement: 7 단계, 이미지 3개 중 1개 Venturer CR20 Speaker Replacement: 7 단계, 이미지 3개 중 2개 Venturer CR20 Speaker Replacement: 7 단계, 이미지 3개 중 3개
    • Do not pull the plastic frame and motherboard apart too hard or the motherboard and plastic frame will not go back together.
    • Flip the motherboard over and push in each of the black clips to disconnect the plastic frame from the motherboard.
    • Proceed to remove the plastic frame gently, being cautious to not fully break the two apart.
  8. Venturer CR20 Speaker Replacement: 8 단계, 이미지 3개 중 1개 Venturer CR20 Speaker Replacement: 8 단계, 이미지 3개 중 2개 Venturer CR20 Speaker Replacement: 8 단계, 이미지 3개 중 3개
    • Gently, pull the tuner wheel up and away from the motherboard.
  9. Venturer CR20 Speaker Replacement, Speaker: 9 단계, 이미지 3개 중 1개 Venturer CR20 Speaker Replacement, Speaker: 9 단계, 이미지 3개 중 2개 Venturer CR20 Speaker Replacement, Speaker: 9 단계, 이미지 3개 중 3개
    • Flip over the motherboard and grab hold of the plastic frame.
    • With a small amount of force, push on the plastic clips, away from you, to eject the speaker from its plastic housing.
결론
작성자
3다른 기여자 명과 함께
Robert Myers
회원 가입일: 01/11/13
54 평판
안내서 5개를 작성함
Cal Poly, Team 5-15, Forte Winter 2013 Cal Poly, Team 5-15, Forte Winter 2013 회원
CPSU-FORTE-W13S5G15
5 회원들
안내서 5개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 1
지난 30일: 8
전체 시간: 484
