소개
This guide is designed to provide you with a visual and technical description to remove the battery of the Verizon Ellipsis 10.
도구
부품
지정된 부품이 없습니다.
Remove the bottom piece of tape securing the battery making sure you are not peeling up anything else in the process.
거의 끝나갑니다!
To reassemble your device, follow these instructions in reverse order using new tape to secure the battery.
결론
다른 3명이 해당 안내서를 완성하였습니다.
