소개
This guide is designed to provide you with a visual and technical description to remove the battery of the Verizon Ellipsis 10.
필요한 것
Remove the bottom piece of tape securing the battery making sure you are not peeling up anything else in the process.
거의 끝나갑니다!
To reassemble your device, follow these instructions in reverse order using new tape to secure the battery.
결론
다른 3명이 해당 안내서를 완성하였습니다.
Can I rig up a tool this was gave to me
Luckily SD card still in tac I let a friend use it for Netflix it was plugged in all nite while watching it could that be the reason it won't come on
ribinstick48 - 답글
