주요 콘텐츠로 건너뛰기
이 안내서에는 최근 변경 사항이 더 있습니다. 최신 비검증 버전으로 전환하십시오.
Verizon Ellipsis 10 Battery Replacement
필요한 것
  1. Verizon Ellipsis 10 Battery Replacement, Back Cover: 1 단계, 이미지 1/1
    • Open the SD/SIM card cover to start prying off the back cover.
  2. Verizon Ellipsis 10 Battery Replacement: 2 단계, 이미지 1/1
    • Start using the iFixit Opening Tool in the SD/SIM area to release the clips holding the back panel on.
  3. Verizon Ellipsis 10 Battery Replacement: 3 단계, 이미지 1/1
    • Follow along the edge of the device to undo all of the retaining clips.
  4. Verizon Ellipsis 10 Battery Replacement: 4 단계, 이미지 1/1
    • Once all the clips are undone, the back panel should come off with little effort.
  5. Verizon Ellipsis 10 Battery Replacement, Battery: 5 단계, 이미지 1/1
    • Remove the bottom piece of tape securing the battery making sure you are not peeling up anything else in the process.
  6. Verizon Ellipsis 10 Battery Replacement: 6 단계, 이미지 1/1
    • Remove the top piece of tape. You can use the iFixit opening tool to get a hold on it.
  7. Verizon Ellipsis 10 Battery Replacement: 7 단계, 이미지 1/1
    • Once you have a hold on the tape, carefully remove it making sure you aren’t damaging the battery in the process.
  8. Verizon Ellipsis 10 Battery Replacement: 8 단계, 이미지 1/1
    • Unplug the battery power connector by sliding the white plastic plug down away from the board.
  9. Verizon Ellipsis 10 Battery Replacement: 9 단계, 이미지 1/1
    • The battery should be free to come out of the device. Make sure not to bend or damage the battery.
결론
To reassemble your device, follow these instructions in reverse order using new tape to secure the battery.
다른 3명이 해당 안내서를 완성하였습니다.
Mary Duran
회원 가입일: 04/03/19
597 평판
안내서 4개 작성하였습니다
댓글 한 개
Has anyone found a source for these batteries?
brianmjones - 답글
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 4
30일 전: 12
전체 시간: 1,855
