주요 콘텐츠로 건너뛰기
Verizon Ellipsis 10 Headphone Jack Replacement
필요한 것
  1. Verizon Ellipsis 10 Headphone Jack Replacement, Back Cover: 1 단계, 이미지 1/1
    • Open the SD/SIM card cover to start prying off the back cover.
  2. Verizon Ellipsis 10 Headphone Jack Replacement: 2 단계, 이미지 1/1
    • Start using the iFixit Opening Tool in the SD/SIM area to release the clips holding the back panel on.
  3. Verizon Ellipsis 10 Headphone Jack Replacement: 3 단계, 이미지 1/1
    • Follow along the edge of the device to undo all of the retaining clips.
  4. Verizon Ellipsis 10 Headphone Jack Replacement: 4 단계, 이미지 1/1
    • Once all the clips are undone, the back panel should come off with little effort.
  5. Verizon Ellipsis 10 Headphone Jack Replacement, Battery: 5 단계, 이미지 1/1
    • Remove the bottom piece of tape securing the battery making sure you are not peeling up anything else in the process.
  6. Verizon Ellipsis 10 Headphone Jack Replacement: 6 단계, 이미지 1/1
    • Remove the top piece of tape using an iFixit opening tool.
  7. Verizon Ellipsis 10 Headphone Jack Replacement: 7 단계, 이미지 1/1
    • Once you have a hold on the tape, carefully remove it making sure you aren’t damaging the battery in the process.
  8. Verizon Ellipsis 10 Headphone Jack Replacement: 8 단계, 이미지 1/1
    • Unplug the battery power connector by sliding the white plastic plug down away from the board.
  9. Verizon Ellipsis 10 Headphone Jack Replacement: 9 단계, 이미지 1/1
    • The battery should be free to come out of the device. Make sure not to bend or damage the battery.
  10. Verizon Ellipsis 10 Headphone Jack Replacement, Headphone Jack: 10 단계, 이미지 1/1
    • Locate headphone jack and volume buttons.
  11. Verizon Ellipsis 10 Headphone Jack Replacement: 11 단계, 이미지 1/1
    • Pull out the blue/white connector from the circuit board.
  12. Verizon Ellipsis 10 Headphone Jack Replacement: 12 단계, 이미지 1/1
    • Gently disconnect the red/black wire from circuit board using a pair of tweezers.
  13. Verizon Ellipsis 10 Headphone Jack Replacement: 13 단계, 이미지 1/1
    • Remove all three M1.5 screws with a Phillips #00 screwdriver.
  14. Verizon Ellipsis 10 Headphone Jack Replacement: 14 단계, 이미지 1/1
    • Pull out the circuit board.
    • Be careful not to lose the button covers, as there is nothing holding them in the device.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Samuel Sowanick
회원 가입일: 04/05/19
294 평판
안내서 2개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 0
전체 시간: 182
