주요 콘텐츠로 건너뛰기
Verizon Ellipsis 10 Motherboard Replacement
필요한 것
  1. Verizon Ellipsis 10 Motherboard Replacement, Back Cover: 1 단계, 이미지 1/1
    • Open the SD/SIM card cover to start prying off the back cover.
  2. Verizon Ellipsis 10 Motherboard Replacement: 2 단계, 이미지 1/1
    • Start using the iFixit Opening Tool in the SD/SIM area to release the clips holding the back panel on.
  3. Verizon Ellipsis 10 Motherboard Replacement: 3 단계, 이미지 1/1
    • Follow along the edge of the device to undo all of the retaining clips.
  4. Verizon Ellipsis 10 Motherboard Replacement: 4 단계, 이미지 1/1
    • Once all the clips are undone, the back panel should come off with little effort.
  5. Verizon Ellipsis 10 Motherboard Replacement, Battery: 5 단계, 이미지 1/1
    • Remove the bottom piece of tape securing the battery making sure you are not peeling up anything else in the process.
  6. Verizon Ellipsis 10 Motherboard Replacement: 6 단계, 이미지 1/1
    • Remove the top piece of tape using an iFixit opening tool.
  7. Verizon Ellipsis 10 Motherboard Replacement: 7 단계, 이미지 1/1
    • Once you have a hold on the tape, carefully remove it making sure you aren’t damaging the battery in the process.
  8. Verizon Ellipsis 10 Motherboard Replacement: 8 단계, 이미지 1/1
    • Unplug the battery power connector by sliding the white plastic plug down away from the board.
  9. Verizon Ellipsis 10 Motherboard Replacement: 9 단계, 이미지 1/1
    • The battery should be free to come out of the device. Make sure not to bend or damage the battery.
  10. Verizon Ellipsis 10 Motherboard Replacement, Camera: 10 단계, 이미지 1/1
    • Remove 4 M1.5 screws holding in the labeled LTE module.
  11. Verizon Ellipsis 10 Motherboard Replacement: 11 단계, 이미지 1/1
    • Use a nylon spudger to pry up the module.
    • It's held in with some clips so there will be a little bit of resistance.
  12. Verizon Ellipsis 10 Motherboard Replacement: 12 단계, 이미지 1/2 Verizon Ellipsis 10 Motherboard Replacement: 12 단계, 이미지 2/2
    • Remove the 4 M1.5 screws holding in the labeled auxiliary LTE/GPS module.
    • The module should come up with a little resistance.
  13. Verizon Ellipsis 10 Motherboard Replacement: 13 단계, 이미지 1/1
    • Use a pair of tweezers to lift up the front camera off its locating post.
  14. Verizon Ellipsis 10 Motherboard Replacement: 14 단계, 이미지 1/2 Verizon Ellipsis 10 Motherboard Replacement: 14 단계, 이미지 2/2
    • Remove the non-conductive tape covering the camera ribbon cable.
    • You may need to remove the white antenna cable to remove the tape.
  15. Verizon Ellipsis 10 Motherboard Replacement: 15 단계, 이미지 1/1
    • Carefully unplug the ribbon cable from the motherboard.
  16. Verizon Ellipsis 10 Motherboard Replacement: 16 단계, 이미지 1/2 Verizon Ellipsis 10 Motherboard Replacement: 16 단계, 이미지 2/2
    • Peel up the ribbon cable carefully as it is glued to the device.
    • After having peeled up the cable, the cameras should be free to come out of the device.
  17. Verizon Ellipsis 10 Motherboard Replacement, Motherboard: 17 단계, 이미지 1/1
    • Remove the non-conductive tape covering two ribbon cables.
  18. Verizon Ellipsis 10 Motherboard Replacement: 18 단계, 이미지 1/1
    • Gently unplug both the orange and white ribbon cables.
  19. Verizon Ellipsis 10 Motherboard Replacement: 19 단계, 이미지 1/1
    • Use tweezers to pry/disconnect both the black and white antenna cables from the top of the motherboard.
  20. Verizon Ellipsis 10 Motherboard Replacement: 20 단계, 이미지 1/1
    • Unplug the last ribbon cable from the bottom of the motherboard.
  21. Verizon Ellipsis 10 Motherboard Replacement: 21 단계, 이미지 1/1
    • Remove all M1.5 screws holding in the motherboard.
  22. Verizon Ellipsis 10 Motherboard Replacement: 22 단계, 이미지 1/1
    • Once all screws are removed, the motherboard should easily come off the device without any resistance.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Marco Bellutta
회원 가입일: 04/05/19
253 평판
안내서 1개 작성함
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 1
30일 전: 1
전체 시간: 354
