주요 콘텐츠로 건너뛰기
Verizon Ellipsis 10 Speaker Replacement
필요한 것
  1. Verizon Ellipsis 10 Speaker Replacement, Back Cover: 1 단계, 이미지 1/1
    • Open the SD/SIM card cover to start prying off the back cover.
  2. Verizon Ellipsis 10 Speaker Replacement: 2 단계, 이미지 1/1
    • Start using the iFixit Opening Tool in the SD/SIM area to release the clips holding the back panel on.
  3. Verizon Ellipsis 10 Speaker Replacement: 3 단계, 이미지 1/1
    • Follow along the edge of the device to undo all of the retaining clips.
  4. Verizon Ellipsis 10 Speaker Replacement: 4 단계, 이미지 1/1
    • Once all the clips are undone, the back panel should come off with little effort.
  5. Verizon Ellipsis 10 Speaker Replacement, Battery: 5 단계, 이미지 1/1
    • Remove the bottom piece of tape securing the battery making sure you are not peeling up anything else in the process.
  6. Verizon Ellipsis 10 Speaker Replacement: 6 단계, 이미지 1/1
    • Remove the top piece of tape using an iFixit opening tool.
  7. Verizon Ellipsis 10 Speaker Replacement: 7 단계, 이미지 1/1
    • Once you have a hold on the tape, carefully remove it making sure you aren’t damaging the battery in the process.
  8. Verizon Ellipsis 10 Speaker Replacement: 8 단계, 이미지 1/1
    • Unplug the battery power connector by sliding the white plastic plug down away from the board.
  9. Verizon Ellipsis 10 Speaker Replacement: 9 단계, 이미지 1/1
    • The battery should be free to come out of the device. Make sure not to bend or damage the battery.
  10. Verizon Ellipsis 10 Speaker Replacement, Speaker: 10 단계, 이미지 1/1
    • Using a Phillips #00 screwdriver, remove the four M1.5 screws from the right speaker.
  11. Verizon Ellipsis 10 Speaker Replacement: 11 단계, 이미지 1/1
    • Remove the black and white wires connected to the motherboard by pulling up on their connections.
    • Remove the three strips of tape.
  12. Verizon Ellipsis 10 Speaker Replacement: 12 단계, 이미지 1/1
    • Remove the four M1.5 screws on the left speaker.
    • Remove the speakers from the device.
결론
Mary Duran
회원 가입일: 04/03/19
597 평판
안내서 4개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 4
전체 시간: 143
