소개
This guide will teach you how to remove the back and replace the battery on the Verizon Ellipsis 7 tablet. A prying tool is required to remove the back plate of the phone, and the process is not very hazardous. This could be useful to replace a faulty battery or if you have multiple batteries to keep your device running on the go.
필요한 것
Power down device by holding down the power button until the screen goes black.
Remove the SIM card from the device to prevent damage.
To remove the SIM card, open the SIM card cover on the side of the device.
Push SIM card in and then pull out after hearing a click.
Remove the charging (micro-USB) port by unscrewing the indicated screws using the Phillips #00 screwdriver.
Disconnect the ribbon cable connecting the charging port board to the motherboard using tweezers.
Use the tweezers to grab the sides of black, plastic connector. Do not grab from the wires or try to wedge it out from the bottom.
다른 11명이 해당 안내서를 완성하였습니다.
댓글 8개
so much for the charging port. You didn’t mention the battery. ?
Well….ok…..but were we here for removing the charging port? Ha ha….I think not. So how about we lift out the battery and unplug it instead. Takes a bit of effort , it seems. That sucker is stuck down pretty good with some really good double sided tape. Lift carefully. I pried it up with the same plastic case tool I used to remove the back cover. The same tool also helped me remove the battery plug.
David Shaw - 답글
Look at the stats..
Why suddenly are so many units failing at or about the same time? I'm not a conspirist but,
Don't you think it's a strange coincidence?
