주요 콘텐츠로 건너뛰기
Verizon Ellipsis 8 Button Replacement
필요한 것
  1. Verizon Ellipsis 8  Button Replacement, Power/Volume Buttons: 1 단계, 이미지 1/1
    • First, use a plastic opening tool in order to slowly pry across the crevasse on the side of the device. This plastic back of the device will un-click during this process and you will remove the back piece.
  2. Verizon Ellipsis 8  Button Replacement: 2 단계, 이미지 1/1
    • Using your fingers, firmly grasp either the power button or the volume buttons and remove them, releasing the clasps that hold the buttons into place.
  3. Verizon Ellipsis 8  Button Replacement: 3 단계, 이미지 1/1
    • Now, using your fingers replace the buttons that you have removed in the previous step with the new functioning buttons. Enter the button in at an angle and press it into place, clicking it into the open slot. To reassemble your device, follow these instructions in reverse order.
결론
Jack
회원 가입일: 02/06/19
589 평판
안내서 3개 작성하였습니다
UC Davis, Team S18-G6, Lore Winter 2019 UC Davis, Team S18-G6, Lore Winter 2019 회원
UCD-LORE-W19S18G6
3 회원들
안내서 3개 작성하였습니다
댓글 한 개
where can i purchase replacement buttons for this device? anyone know? Thanks!!!
Broadcast Depth - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 11
전체 시간: 472
