주요 콘텐츠로 건너뛰기
Verizon Ellipsis 8 Antenna Replacement
필요한 것
  1. Verizon Ellipsis 8 Antenna Replacement, Battery: 1 단계, 이미지 1/1
    • Using a plastic opening tool, slowly pry along the seam running along the edge of the device until the back case snaps free.
    • Remove the back case.
  2. Verizon Ellipsis 8 Antenna Replacement: 2 단계, 이미지 1/1
    • Using a Phillips #00 screwdriver, remove the two 0.1 mm screws on the green bracket.
  3. Verizon Ellipsis 8 Antenna Replacement: 3 단계, 이미지 1/1
    • Once you remove the backing of the Verizon Ellipsis 8, gently use the spudger to lift one side of the tape. Once you have lifted the tape, slowly remove it until it is completely off the battery.
  4. Verizon Ellipsis 8 Antenna Replacement: 4 단계, 이미지 1/1
    • Lift and remove the battery from the device.
  5. Verizon Ellipsis 8 Antenna Replacement, Antenna: 5 단계, 이미지 1/1
    • Using a plastic opening tool, lift the motherboard along the top right edge of the device.
  6. Verizon Ellipsis 8 Antenna Replacement: 6 단계, 이미지 1/3 Verizon Ellipsis 8 Antenna Replacement: 6 단계, 이미지 2/3 Verizon Ellipsis 8 Antenna Replacement: 6 단계, 이미지 3/3
    • Once you have access to the antenna, remove it and replace it.
결론
Jack
회원 가입일: 02/06/19
589 평판
안내서 3개 작성하였습니다
UC Davis, Team S18-G6, Lore Winter 2019 UC Davis, Team S18-G6, Lore Winter 2019 회원
UCD-LORE-W19S18G6
3 회원들
안내서 3개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 8
전체 시간: 274
