주요 콘텐츠로 건너뛰기
Verizon Ellipsis 8 Screen Replacement
필요한 것
  1. Verizon Ellipsis 8 Screen Replacement, Battery: 1 단계, 이미지 1개 중 1개
    • Using a plastic opening tool, slowly pry along the seam running along the edge of the device until the back case snaps free.
    • Remove the back case.
  2. Verizon Ellipsis 8 Screen Replacement: 2 단계, 이미지 1개 중 1개
    • Using a Phillips #00 screwdriver, remove the two 0.1 mm screws on the green bracket.
  3. Verizon Ellipsis 8 Screen Replacement: 3 단계, 이미지 1개 중 1개
    • Once you remove the backing of the Verizon Ellipsis 8, gently use the spudger to lift one side of the tape. Once you have lifted the tape, slowly remove it until it is completely off the battery.
  4. Verizon Ellipsis 8 Screen Replacement: 4 단계, 이미지 1개 중 1개
    • Lift and remove the battery from the device.
  5. Verizon Ellipsis 8 Screen Replacement, Speaker: 5 단계, 이미지 3개 중 1개 Verizon Ellipsis 8 Screen Replacement, Speaker: 5 단계, 이미지 3개 중 2개 Verizon Ellipsis 8 Screen Replacement, Speaker: 5 단계, 이미지 3개 중 3개
    • Remove all 5 screws from their respective holes using the Phillips #00 screwdriver.
    • Remove the speaker from the device.
  6. Verizon Ellipsis 8 Screen Replacement, Screen: 6 단계, 이미지 1개 중 1개
    • Using a guitar pick or a metal spudger, remove the old screen from the device from the back of the tablet.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
4다른 기여자 명과 함께
Sreedhar Kesari
회원 가입일: 11/11/19
190 평판
안내서 2개를 작성함
IUPUI, Team S2-G2, Stella Fall 2019 IUPUI, Team S2-G2, Stella Fall 2019 회원
IUPUI-STELLA-F19S2G2
4 회원들
안내서 2개를 작성함
1가이드 댓글
This guide is incomplete, with several steps and details omitted.
As it is now, this guide is inadequate for anyone who has never done anything like this before. Yet it's also almost completely unnecessary for anyone with a little experience doing similar repairs.
So, it's of almost no use to anyone!
ajfranzman - 답글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 6
지난 30일: 20
전체 시간: 1,225
