이 버전에는 잘못된 편집 사항이 있을 수 있습니다. 최신 확인된 스냅샷으로 전환하십시오.
필요한 것
이 단계는 번역되지 않았습니다. 번역을 도와주십시오
Using a plastic opening tool, slowly pry along the seam running along the edge of the device until the back case snaps free.
Remove the back case.
Using a Phillips #00 screwdriver, remove the two 0.1 mm screws on the green bracket.
Once you remove the backing of the Verizon Ellipsis 8, gently use the spudger to lift one side of the tape. Once you have lifted the tape, slowly remove it until it is completely off the battery.
Remove all 5 screws from their respective holes using the Phillips #00 screwdriver.
Remove the speaker from the device.
Using a guitar pick or a metal spudger, remove the old screen from the device from the back of the tablet.
다른 한 분이 해당 안내서를 완성하였습니다.
