소개
What you can expect from this guide is a step by step process on how to remove the plastic case on a Verizon Ellipsis Jetpack MHS800L.
필요한 것
이 단계에 사용된 도구:Phillips #00 Screwdriver$5.49
With the device on its back and the label facing you, remove the rubber screw cover on the top left corner of the device.
Under the rubber circle, remove the 1.25 mm screw using a Phillips #00 Screwdriver.
이 단계에 사용된 도구:iFixit Opening Picks (Set of 6)$4.99
Use a plastic pick at the seams and pry open the case.
다른 2명이 해당 안내서를 완성하였습니다.
