주요 콘텐츠로 건너뛰기
Verizon Jetpack 4G LTE Mobile Hotspot Battery Replacement
필요한 것
  1. Verizon Jetpack 4G LTE Mobile Hotspot Battery Replacement, Battery: 1 단계, 이미지 1/2 Verizon Jetpack 4G LTE Mobile Hotspot Battery Replacement, Battery: 1 단계, 이미지 2/2
    • Hold the device with your non-dominant hand, looking at the back of the device, taking note of the small notch along the edge.
  2. Verizon Jetpack 4G LTE Mobile Hotspot Battery Replacement: 2 단계, 이미지 1/2 Verizon Jetpack 4G LTE Mobile Hotspot Battery Replacement: 2 단계, 이미지 2/2
    • While holding the device with your non-dominant hand, use your dominant hand to gently pry the back casing off the device. The most effective way to do this is by gripping the small notch.
    • If it doesn't come off, try using alternative grips that are the most comfortable for you. Try using your fingernails to pry up at the corner or around the edge of the backing. The case should come off easily.
    • The back should be completely removed.
  3. Verizon Jetpack 4G LTE Mobile Hotspot Battery Replacement: 3 단계, 이미지 1/1
    • The battery should now be visible. Gently grasp the edges to lift it out of the device.
    • The device in picture no longer has a battery but a normal device will likely have a battery once opened.
결론
Analisa Caso
회원 가입일: 10/08/18
232 평판
안내서 2개 작성하였습니다
Marist, Team S1-G3, Chaterdon Fall 2018 Marist, Team S1-G3, Chaterdon Fall 2018 회원
MARS-CHATERDON-F18S1G3
3 회원들
안내서 8개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 7
30일 전: 37
전체 시간: 4,629
