주요 콘텐츠로 건너뛰기
Verizon Wireless CDM 7075 Keypad Replacement
필요한 것
  1. Verizon Wireless CDM 7075 Keypad Replacement, Battery: 1 단계, 이미지 1/2 Verizon Wireless CDM 7075 Keypad Replacement, Battery: 1 단계, 이미지 2/2
    • Remove the back panel by first pressing and holding the gray button on the back. While doing that also press and slide the panel down and off.
  2. Verizon Wireless CDM 7075 Keypad Replacement: 2 단계, 이미지 1/1
    • Carefully remove the battery from the phone by prying the battery from the top.
  3. Verizon Wireless CDM 7075 Keypad Replacement, Keypad: 3 단계, 이미지 1/1
    • Pry off the top cover on the back of the phone.
  4. Verizon Wireless CDM 7075 Keypad Replacement: 4 단계, 이미지 1/1
    • You will then remove the screws from the back of the phone.
  5. Verizon Wireless CDM 7075 Keypad Replacement: 5 단계, 이미지 1/1
    • Next you will pry apart the two halves of the phone.
    • Make sure you do not to damage the ribbon cable connecting both halves
  6. Verizon Wireless CDM 7075 Keypad Replacement: 6 단계, 이미지 1/1
    • Then use the plastic opening tool to remove the motherboard from the front half of the phone.
  7. Verizon Wireless CDM 7075 Keypad Replacement: 7 단계, 이미지 1/1
    • Next you will peel off the keypad after the motherboard is removed.
    • Be sure you do not to tear the brown connector tape.
    • Lastly insert the new keypad.
결론
To reassemble your device follow these instructions in reverse order.
다른 한 분이 해당 안내서를 완성하였습니다.
Corey Ryman
회원 가입일: 10/14/11
255 평판
안내서 4개 작성하였습니다
James Madison, Team 2-4, Allen Fall 2011 James Madison, Team 2-4, Allen Fall 2011 회원
JMU-ALLEN-F11S2G4
3 회원들
안내서 8개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 1
전체 시간: 1,132
