주요 콘텐츠로 건너뛰기
Verizon Wireless CDM 7075 Screen Replacement
필요한 것
  1. Verizon Wireless CDM 7075 Screen Replacement, Battery: 1 단계, 이미지 1/2 Verizon Wireless CDM 7075 Screen Replacement, Battery: 1 단계, 이미지 2/2
    • Remove the back panel by first pressing and holding the gray button on the back. While doing that also press and slide the panel down and off.
  2. Verizon Wireless CDM 7075 Screen Replacement: 2 단계, 이미지 1/1
    • Carefully remove the battery from the phone by prying the battery from the top.
  3. Verizon Wireless CDM 7075 Screen Replacement, Screen: 3 단계, 이미지 1/1
    • Remove the rubber plugs from the screw holes around the screen with the opening tool.
  4. Verizon Wireless CDM 7075 Screen Replacement: 4 단계, 이미지 1/1
    • Remove the four screws from around the phone's screen with a Phillips screwdriver.
  5. Verizon Wireless CDM 7075 Screen Replacement: 5 단계, 이미지 1/1
    • Pry the top cover off the phone with a plastic opening tool.
  6. Verizon Wireless CDM 7075 Screen Replacement: 6 단계, 이미지 1/1
    • Remove the screen assembly from the phone.
  7. Verizon Wireless CDM 7075 Screen Replacement: 7 단계, 이미지 1/1
    • Pry the circuit board off of the screen with the opening tool.
결론
Corey Ryman
회원 가입일: 10/14/11
255 평판
안내서 4개 작성하였습니다
James Madison, Team 2-4, Allen Fall 2011 James Madison, Team 2-4, Allen Fall 2011 회원
JMU-ALLEN-F11S2G4
3 회원들
안내서 8개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 1
전체 시간: 1,090
